Losi® TEN Rally-X 1/10 topic
motorsports
Forum veteraan
binnenkort verkrijgbaar :
The Losi® TEN Rally-X takes the proven TENSCTE platform to the streets with unprecedented driving characteristics. Armed with new AVC™ (Active Vehicle Control™) technology, the Ten Rally-X utilizes intuitive sensors to adjust steering and throttle output at a rate faster than humanly possible, this provides a stable and controlled driving experience where drifts are more dramatic, and accelerations are consistently fluid. This advanced stability is indispensable as the Rally-X comes equipped with an exceedingly powerful brushless 4-pole brushless motor and a waterproof design that provides drivers with fewer limitations, and more opportunities to tear up the ground.
TEN- Rally X RTR: 1/10 4WD Rally Ready-to-Run
At a Glance
The Losi® TEN-Rally X takes the proven TEN-SCTE platform to the streets with unprecedented driving characteristics. Armed with new AVC™ (Active Vehicle Control™) technology, the TEN-Rally X utilizes intuitive sensors to adjust steering and throttle output at a rate faster than humanly possible, this provides a stable and controlled driving experience where drifts are more dramatic, and accelerations are consistently fluid. This advanced stability is indispensable as the Rally X comes equipped with an exceedingly powerful brushless 4-pole brushless motor and a waterproof design that provides drivers with fewer limitations, and more opportunities to tear up the ground.
AVC (Active Vehicle Control) Technology
AVC Technology is the newest Spektrum™ RC innovation from Horizon Hobby. This Spektrum stabilization system adds a whole new level of control to your RC driving experience. AVC technology utilizes sensors to adjust steering and throttle output, providing you with a more stable and controlled driving experience.
Heading Hold – AVC technology’s Heading Hold feature allows you to focus on driving faster with the confidence of complete control. Heading Hold manages steering output by automatically aligning a vehicle’s tires to your chosen direction, and, when centered, maintains that direction regardless of the amount of traction or ruggedness of terrain. Now lining up and hitting that big jump just became as easy as punching the trigger.
Throttle Management – The Throttle Management function enabled by AVC technology assists in maintaining maximum grip in even the most challenging of environments. AVC technology adjusts a vehicle’s throttle output in order to minimize wheel slip, allowing a driver to accelerate with total control. Whether you’re heading into a turn with too much speed or driving on a slippery surface where traction is minimized, Throttle Management assists in maximizing traction when you need it the most.
Adjustable Sensitivity – The amount of stability assistance that AVC technology provides can be adjusted to suit any combination of skill level, driving style and terrain. Depending on which Spektrum™ transmitter you are using, adjustments can be made using programming functions or a steering rate knob. AVC can also be turned completely off for a traditional driving experience where you can test your driving abilities.
Features
Durable, aluminum, Race-proven TEN Platform
Dynamite® Waterproof, 130A LiPo Compatible ESC
Dynamite 4-Pole 3900Kv Brushless Motor
Spektrum™ Waterproof SRS4200 Receiver with 2.4GHz
Spektrum™ DX2E Transmitter with DSMR
Aluminum, Adjustable Oil-filled shocks
Resilient Front and Rear Bumpers
Pre-decorated, eye-catching body With wing
Rally Inspired On/off-road tires
Waterproof electronics package
AVC™ (Active Vehicle Control™) Equipped
Product Specifications
Type:4WD Rally
Scale:1/10
Length:21.26 in (540mm)
Width:11.65 in (296mm)
Height:7.08 in (180mm)
Wheelbase:13.15 in (334mm)
Chassis:2.5mm Aluminum
Suspension:4-wheel independent
Drivetrain:Shaft-driven 4WD
Tire Type:On/Off-road All-terrain Performance
Motor or Engine:Dynamite Fuze 3900Kv 4-Pole
Speed Control:Dynamite Fuze, Waterproof 130A Brushless
Radio:Spektrum DX3E with DSMR Technology
Speed:50+ MPH
Body:Pre-decorated Rally body
Ball Bearings:Full-equipped
Recommended Environment:Outdoor
1.RELIABLE ALUMINUM CHASSIS BUILT ON TEN PLATFORM
2.ALUMINUM, ADJUSTABLE, OIL-FILLED, COIL-OVER SHOCKS
3.WATERPROOF* DYNAMITE® 130A BRUSHLESS ESC
4.DYNAMITE FOUR-POLE, 3900KV MOTOR
5.SPEKTRUM™ SRS4200 2.4GHZ RECEIVER WITH AVC STABILITY TECHNOLOGY
6.SEALED ELECTRONICS BOX TO KEEP OUT MUD AND DEBRIS
7.SIMPLE TO ADJUST ALUMINUM MOTOR MOUNT
8.DIGITAL, HIGH-TORQUE STEERING SERVO
9.RALLY INSPIRED WHEELS FOR FORM AND FUNCTION
10.RALLY STYLE TIRES FOR OFF ROAD AND ON ROAD EXCITEMENT
11.REALISTIC AND FUNCTIONAL BUMPERS
12.ADJUSTABLE TURNBUCKLES WITH CAPTURED END
bron: losi.com
Mwah, zijn er nog eigenaren van deze auto ?, is toch afgeleid van de Ten-SCTe variant,of zijn daar ook geen eigenaren van ?.
Hier mijn Rally
Misschien met een andere motormount , maar met de standaard is 36mm de grootste diameter. Echter hoef ik niet groter , waarom?: rij nu op 4S en 2200Kv , voldoende trekkracht onderin , goede acceleratie en goede rijtijden .Lekker om goed te controleren met deze combi .
Ik ben nooit zo van 12 in dozijn , mbt de kap , dus het " schreeuwende" TEN rally x mag eraf , nezoals de sluik reclame van S(j)pektrum:stout:o_O. Dus wat stickers van GoPro erop . Met de GoPro wil ik nog wel eens een keer gaan rijden , op het dak of binnenin naar voren gericht :koud:
Ah, op 4s, daar twijfelde ik nog over.
Dat bevalt dus wel?
Het ziet er mooi uit zo, Spektrum wil je inderdaad geen reclame voor maken ;)
Hmm, steeds als ik dit zie baal ik dat ik mijn Ten-T nog niet kan kopen.. :)
Als u 17mm hexes heeft gevonden, zou u dan een linkje willen plaatsen?
Ok, ik ga even zoeken, bedankt.
Nu alleen wachten tot ik betaald krijg.. zou de 23ste al gebeurd zijn...
Hmm, 44 euro heb ik nu niet..
Wat is er zo speciaal aan dit setje dan, normaal kosten ze 2 tientjes oid?
Ik denk de gebruikte diameter van de aandrijfas [emoji15]. De hotracing en str rc e.d liggen op ebay rond de 22-30 dollar , ex porto en ex axle's . Maar beide heb ik gehad op de slash en waren van matige kwaliteit . En bij de zoektocht naar hex conversie setjes voor de Losi kwam ik niks tegen , traxxas en hpi setjes legio .
Ach misschien " te duur", maar als de maatvoering goed is en de kwaliteit ook , vindt ik het wel waard , zeker bij hotracing is de binnen diameter niet altijd goed . Bij deze set wordt het wielspoor niet gelijk 12-25 mm breder (wordt gedeeltelijk gecompenseerd door de 1/8 velgen ).
We zullen zien of het een "kat in de zak " aankoop is als ze er zijn .
Er zijn legio setjes 17mm meenemers.
Dan zou ik toch daartussen ff gaan zoeken naar de juiste maat.
Wat zijn de maten van de standaard assen? Er zal er vast wel 1 passen...
