FORUMLEDEN met NOSTALGIE......"vreemde" kisten (deel 2)
Discussie in 'De Modelbouwkroeg' gestart door NVM, 8 jan 2011.
  1. jef
    jef PH-SAM
    14 jan 2011
    Hulshout België
  2. sanmos
    sanmos
    2 okt 2008
    nijkerk
    :feli: aan u de volgende
  3. jef
    jef PH-SAM
    14 jan 2011
    Hulshout België
    Nieuwe zoektocht
    Succes , groeten Jef ;)
  4. jef
    jef PH-SAM
    14 jan 2011
    Hulshout België
    TIP;
    Ontwerper was Amerikaans maar het vliegtuig is gebouwd in Frankrijk
    Groeten Jef
  5. Ariel
    Ariel PH-SAM
    8 dec 2009
    Hoorn NH
    Sloan Bicurve
    From 1910 to 1912 the American John Sloan built his series of "bicurve" biplanes in a small workshop in the Paris suburb of Charenton. As with so many of the early designers and builders, it is difficult to determine how many of the machines appearing under his name were new ones, or merely earlier ones modified and developed.
    His first was shown in 1910, typical of his bicurve designs with the shorter top wing arching down at the tips almost meeting inboard of the tips of the lower wing, with the extended leading and trailing edges of the upper wing joined to those of the lower. The lower wing had some dihedral, and then its tips drooped also, with large ailerons on the trailing edges near the ends. The long uncovered rectangular fuselage sat 2 in tandem behind the engine; a tall rectangular rudder stood up at the rear above a long tailplane set at a high angle on the fuselage. The elevators were connected to a forward elevator mounted on outriggers. The aeroplane rested in front on 2 pairs of wheels with a skid between each pair, and a tailwheel; the latter was replaced with a skid before the end of the year. The lower wings were called lifting surfaces and the upper ones stabilizing surfaces: the theory was that the downward curve of the lower wings would "slow the chute if the engine cut."
    (Span: (upper) 8 m; (lower) 10.95 m; chord: (upper) 2 m; (lower) from 2 to 2.9 m at the tip; length: 11.3 m; wing area: 49 sqm; speed: c 75 kmh; 50 hp Gnome with a 2.5 m diameter Sloan propeller)
    A similar machine, or the same one altered, was often photographed in flight. The forward elevator was gone, and a 35 hp Labor provided power through chains to the 2 tractor propellers. The pilot sat in a sort of bucket. Another version - or modification - flew next, with the Gnome and a single tractor propeller, front elevator, but with a less-drooping top wing. It crashed in 1911.
    Sloan's penultimate reported flying machine was flying in 1912 at Issy, seemingly a throwback to the 1910 designs, with the twin skid of the Concours Militaire entry; a final design was similar to the 1912 military aeroplane but with a small inline 4-cylinder motor.
    In the years 1911-1912 he was working on plans fora 18.5-meter span Calais-Dover passenger biplane, with a single big float and a boat-shaped fuselage and a 100 hp Clerget; it was not built.
    Johannes
  6. jef
    jef PH-SAM
    14 jan 2011
    Hulshout België
    Proficiat :thumbsup:
    Op naar de volgende Johannes
    Groeten Jef
  7. Ariel
    Ariel PH-SAM
    8 dec 2009
    Hoorn NH
    En hier een nieuwe uitdaging. :)
    Johannes
  8. Henri Kaper
    Henri Kaper verslagschrijvers
    25 nov 2006
    Den Haag
    Is het een Nurflügel?
  9. Ariel
    Ariel PH-SAM
    8 dec 2009
    Hoorn NH
    Nee, het is geen Nurflügel, wel een Duits toestel.
    Johannes
  10. Henri Kaper
    25 nov 2006
    Den Haag
    Waar is z'n kielvlak dan?
  11. Ariel
    Ariel PH-SAM
    8 dec 2009
    Hoorn NH
    Hij is nog niet af. ;)
    Er zit een 4 PK Siemens motor op het toestel. :D
    Johannes
  12. steffe
    steffe
    20 dec 2004
    Belgie
    hoi johannes
    het plaatje is verdwenen...... o_O
  13. TIMBERWOLF
    TIMBERWOLF Forum veteraan
    28 aug 2008
    noord-holland
    welk plaatje
  14. ron van sommeren
    31 aug 2002
    Ik vermoed het plaatje van laatste opdracht, in bericht #2307.
    Sabbatical gehad Steffe?
  15. ramses
    21 sep 2008
    NB NL
  16. ramses
    21 sep 2008
    NB NL
    Oke, een nieuwe...
    En een hele makkelijke om af te trappen:
    Groeten, Ramses
  17. ron van sommeren
    31 aug 2002
    Ik weet het zo niet, maar het stabilo halverwege het kielvlak doet me denken aan Gloster.
    Roundel/registratie wegpoetsen?
    Laatst bewerkt: 27 jul 2017
  18. steffe
    steffe
    20 dec 2004
    Belgie
    zo te zien een oud toestel van de RAF.....
    dag ron....
    jaaa ik kben weer in het land... :)
    steffe
  19. jef
    jef PH-SAM
    14 jan 2011
    Hulshout België
  20. ron van sommeren
    31 aug 2002
    Èg nie makkelijk nie, ik had er nog nooit van gehoord/gezien/gelezen: "My, are you ugly." Terwijl ik de bijvoorbeeld Swordfish wel kende, en de Tirpitz ook.
    Nu ken ik beide, beetje bijgelezen :)
    Laatst bewerkt: 28 jul 2017
