GR 130 First experience.
Discussie in 'Zelfbouw turbines' gestart door SPOTTER, 22 jan 2021.
  1. SPOTTER
    SPOTTER
    10 jun 2015
    Thanks Gerald
    I can't download the file from your site it asks me for a password,
    you can send me the file to my mail
    spotter0067@gmail.com
  2. SPOTTER
    SPOTTER
    10 jun 2015
    Thanks Gerald
    spotter0067@gmail.com[​IMG]
  3. Gerald Rutten
    Gerald Rutten
    6 mei 2005
    Zuidelijk
    Just send by mail, I will try and figure out how I can change that on my homepage.
  4. SPOTTER
    SPOTTER
    10 jun 2015
    Today I'm building the turbine shaft, I turned with a 6 ° angle to the cone, unfortunately the cone is 27mm long and not 18mm as in the drawing, where did I go wrong? is it right even so or do I have to rebuild it?
  5. Gerald Rutten
    Gerald Rutten
    6 mei 2005
    Zuidelijk
    Nice work! :)
  6. Gerald Rutten
    Gerald Rutten
    6 mei 2005
    Zuidelijk
    I think this will be fine, as long as the thickest part stay the original diameter.
    Rgds,
  7. SPOTTER
    SPOTTER
    10 jun 2015
    Ok thanks it's good news for me
    if you want to send me the file, my email address is
  8. SPOTTER
    SPOTTER
    10 jun 2015
    I have finished turning the turbine shaft now I have to do the grinding.[​IMG]
  9. SPOTTER
    SPOTTER
    10 jun 2015
    Even the parts of the combustion chamber are ready, they are in stainless steel 304, soon I will have a sheet of stainless steel 310ss which has characteristics similar to inconel
  10. SPOTTER
    SPOTTER
    10 jun 2015
    I apologize to the readers of this beautiful forum if I repeat some messages I do not know the procedures well and often make a mistake.
  11. SPOTTER
    SPOTTER
    10 jun 2015
    In this period I am working hard to build tools that I need in the construction of the turbine then I will publish some photos
  12. SPOTTER
    SPOTTER
    10 jun 2015
    I bought many types of capillary tubes for the feeding system, these are various sizes in 316 stainless steel.
    [​IMG] [​IMG] [​IMG]
  13. SPOTTER
    SPOTTER
    10 jun 2015
    I bought these capillary tubes in china, the 6mm tubes are 304 stainless steel
  14. SPOTTER
    SPOTTER
    10 jun 2015
    These tubes have a diameter of 6.35mm and 7.90mm are made in Incoloy 800.
  15. SPOTTER
    SPOTTER
    10 jun 2015
    I also bought some brass capillary tubes-
  16. athome
    athome
    13 okt 2016
    Schweiz
    Hi Gerald
    Time has passed and I did not do a lot on turbines.
    Very interesting this drawing. It has already a smaller angle (14°) your drawing on your website hast still 17°
    I've reverse engineered and created this old JG100 Diffusor (https://www.rcuniverse.com/forum/rc-jets-120/11262454-gr130-7.html) and it seems to work much better / No surging. Fighting with other problems right now :)
    Regards Lukacs
  17. SPOTTER
    SPOTTER
    10 jun 2015
    Hi everyone
    I warn you that I have not abandoned the GR130 project, the desire to continue is stronger than ever, some work commitments did not allow me to continue, then I dedicated myself to the repairs of some of my models and now I am building a hauler and a Pilatus b4.
  18. SPOTTER
    SPOTTER
    10 jun 2015
    Yesterday I had a day off and I wanted to try to build the external part of the combustion chamber, unfortunately the rush made me mistake the punching, the diameter of the largest holes and the height of the sheet, but it served me as an experience, next time he was more careful.[​IMG] [​IMG]
    gpman vindt dit leuk.
  19. SPOTTER
    SPOTTER
    10 jun 2015
    Also yesterday I did another job, for the first ignition of the turbine I do not want to use 70 euro GWR bearings, if something does not work I would have a great waste of money, I bought 4 hybrid fuji bearings with 7 ceramic balls, I disassembled them, I modified the rings and built a bearing of 11 balls, the modification was perfectly successful, the balls are kept inside without the possibility of going out because the entrance has the right tolerance, I hope well.[​IMG] [​IMG] [​IMG]
  20. athome
    athome
    13 okt 2016
    Schweiz
