CleanFlight Ervaringen
Discussie in 'Multicopters electronica' gestart door BorisB, 9 dec 2014.
  1. FedorCommander
    FedorCommander
    30 okt 2014
    Den Haag
    Its better to have it tuned BEFORE... :)
  2. BorisB
    BorisB Forum veteraan
    16 mei 2012
    Brabant
    It's 4,8ms delay with default gyro_lpf of 42hz :D
    The cli command has been changed to dterm_cut_hz....it;'s easier to understand for everyone.
    Zie bovenstaande comment. De cli command in de laatste build is veranderd. Wellicht jouw probleem :D
    Nogmaals de link
    https://dl.dropboxusercontent.com/u/31537757/cleanflight/cleanflight_NAZE.hex
    set gyro_lpf = 188
    set dterm_cut_hz = 17
  3. FedorCommander
    FedorCommander
    30 okt 2014
    Den Haag
    Boris, i meant for default gyro_lpf of 42 hertz of course (which most of us use)...
    Damn, you are changing it all the time ;) Switched my basher yesterday to pidc1 with pt1 filter... Strangly enough have lost some power... Weird. Will investigate later on.
  4. BorisB
    16 mei 2012
    Brabant
    This is the final PR. Same thing, but just cleaner code.
    You should not lose power :D.
  5. FedorCommander
    FedorCommander
    30 okt 2014
    Den Haag
    I know, i saw the code ;) I am curious myself what happened. Its NOT related to your changes anyway. I will roll back and retrace my steps.
  6. jereo
    jereo
    16 dec 2010
    vorden/ tolkamer
    Iemand hier een idee wat dit kan zijn?dit gebeurt op half gas...
  7. Trams
    Trams
    7 okt 2008
    Houten
    Lijkt er op dat de motoren verkeerd op het bordje aangesloten zitten. Heb namelijk kort geleden het zelfde gehad.
  8. jereo
    jereo
    16 dec 2010
    vorden/ tolkamer
    Volgorde aangehouden zoals het in cleanflight bij quad x staat. Klopt gewoon
  9. jereo
    jereo
    16 dec 2010
    vorden/ tolkamer
    Net op 3 s getest... Minder heftig maar zelfde effect.
  10. FedorCommander
    FedorCommander
    30 okt 2014
    Den Haag
    1. check sensors are working correct in the configurator
    2. check motor connection
    3. check motor rotation direction
    4. check yaw_direction=?
    5. check props cw and ccw!
    Well, usual pre maiden checks!
  11. Trams
    Trams
    7 okt 2008
    Houten
    Inderdaad, en dubbel check. Ik denk soms ook dat het allemaal goed zit, maar kijk er dan toch overheen.
  12. jereo
    jereo
    16 dec 2010
    vorden/ tolkamer
    Everything is fine! Sure of that!
  13. FedorCommander
    FedorCommander
    30 okt 2014
    Den Haag
    Its hard to say what its trying to do, really. If it violently tries to flip, usually sensor layout is not the same as motor layout. So when it tiltet left, it tries to correct with other then left motors and makes it worse. Try to see WITHOUT props. COnnect to configurator, on motor tab, arm it and try to rotate it and see which motors are trying to compensate your actions. Do it in RATE mode. For yaw, roll and tilt. AFTER that you are good to mount props!!!
  14. FedorCommander
    FedorCommander
    30 okt 2014
    Den Haag
    So, if you pitch forward, motors 1,3 (forward ones) should compensate (work against you). And so on. If you give STICK command, it should work WITH you. So roll left will activate motors 1,2.... You get the idea.
  15. jereo
    jereo
    16 dec 2010
    vorden/ tolkamer
    Ok I will do that test.
    post it in a few minutes
  16. FedorCommander
    FedorCommander
    30 okt 2014
    Den Haag
    Take your time. Its cheaper that way :)
  17. jereo
    jereo
    16 dec 2010
    vorden/ tolkamer
    Damn... If i roll left motor 3 and 4 speed up. Roll right motor 1 and 2 speeds up.
    So....this is my problem?
  18. FedorCommander
    FedorCommander
    30 okt 2014
    Den Haag
    u rol by hand or with sticks?
  19. jereo
    jereo
    16 dec 2010
    vorden/ tolkamer
    By hand
  20. FedorCommander
    FedorCommander
    30 okt 2014
    Den Haag
    its ok then
