Algemeen #7407 Traxxas Rally 1:10 Topic
Discussie in 'Electro offroad' gestart door Scaler, 7 okt 2012.
  1. Scaler
    Scaler
    3 nov 2011
    Innovative New Chassis
    The innovation designed into the Rally begins with an all-new low-CG chassis that's not like anything you've seen before. Extreme Brushless Power and 4WD requires a chassis that won't flex under load for arrow-straight, hard-charging acceleration. To offer the required rigidity, smoothly integrated ribs form a triangulated structure that's optimized for the loads imparted by the suspension and powertrain. Underneath, the chassis is ultra-smooth to reduce drag and prevent snags driving through brush.
    Low Center of Gravity
    Rally introduces a new low center of gravity chassis for the ultimate handling experience. The race-tuned ride height paired with the high-performance Ultra Shocks deliver off-road versatility that allows you to tackle rough terrain and big obstacles. On the track, the advantage of a low center of gravity (cg) is noticed instantly by the lower lap times. Rally feels planted and secure at speed and at the same time delivers authentic rally handling and realism that makes rally racing such incredible fun.
    Perfect Weight Bias
    Each component on the chassis was carefully positioned for optimal weight distribution and space utilization. The result is perfect weight bias for neutral handling precision. The bulk of the mass is distributed down the centerline of the chassis for smooth, stable cornering.
    Modular Simplicity
    Old designs made servicing of 4-wheel drive vehicles cumbersome and time-consuming. Traxxas has a better way. Modular design allows the entire front section to be removed with just 5-screws, and the rear assembly with just 4-screws. In less than a minute using a power screwdriver you have full access for easy service and adjustment. Click the video tab above to learn more about this feature!
    The World's Most Advanced Ready-To-Race® Radio System
    Total Control. The Rally feratures the world's most advanced Ready-To-Race® radio system for precise, long-range control. Comfortable, powerful, and reliable, the all-new Traxxas® TQi™ radio system matches a full complement of tuning features with a high-output 2.4GHz signal, and proven Traxxas reliability for rock-solid performance. It's so advanced, it doesn't even have an external antenna. However, the most important new feature may already be in your pocket. The TQi can be equipped with an optional Docking Base (#6510) that turns your iPhone® or iPod touch® into a powerful tuning tool for your Traxxas model. The full-color display combines with the Traxxas Link™ App to deliver an intuitive, high-definition, full-color graphical user interface that unlocks the mysteries of optimizing your radio system for ultimate vehicle control.
    5-channel Micro Receiver with Fail-Safe Security
    The TQi 2.4GHz micro receiver fits easily into any vehicle, and features dual channel-1 outputs for easy installation in vehicles with dual steering servos—no Y-harness necessary! The integrated LINK button makes it fast and easy to bind the receiver, and the two-color LED indicates power-on and bind status for fool-proof control and convenience. Traxxas Link Model Memory allows the receiver to recognize up to thirty TQi 2.4GHz Traxxas Link enabled transmitters—just switch on and drive. In the event of signal loss due to an accidental switch-off or depleted batteries, the receiver will automatically return the throttle to neutral and hold the last commanded steering position. The Fail Safe programming is built-in and does not need to be set or activated. Three telemetry ports are incorporated in the 5-channel receiver to allow real-time data to be transmitted from your Traxxas model to the TQi transmitter.
    Included 7-Cell Battery Pack
    Rally includes a genuine Power Cell Battery Pack to make sure you experience all the performance that's been engineered into your Traxxas model. Power Cell packs are optimized for free-flowing power and maximum punch with premium quality, low-resistance cells; flexible, silicone-jacketed 12-gauge wire; heavy-duty welded tabs; and Traxxas' high-output, gold plated, high-current connectors. Precision assembly with attractive, individually wrapped cells and clear overwrap complete the Traxxas Power Cell package, and seven cells give Rally 8.4 volts of motivation for maximum speed.
    Versatile Battery Compartment
    The Rally adapts to multiple battery configurations to accept today's technology and tomorrow's innovations. 6 or 7-cell NiMH battery packs and a variety of LiPo battery configurations can be installed easly.
    Integrated Personal Transponder Mount
    The integrated personal transponder mount makes it easy to install your transponder and move it to the other Traxxas vehicles in your fleet. No tape required, two screws is all it takes. Traxxas makes racing easy!
    Waterproof Receiver Box
    The Rally's receiver is fully enclosed for protection from the elements when your rally race rages through rain, mud, or snow. The antenna and servo wires route neatly through a special watertight seal, and a custom blue O-ring seals the box to protect the receiver from water. The enclosure can be opened and closed without losing the sealing properties of the box, allowing the receiver to be removed for service, or for aftermarket receivers to be installed. Patent pending.
    Velineon® VXL-3s ESC
    The Velineon VXL-3s speed control is loaded with high-grade technology to precisely deliver maximum power to the motor. It's engineered for today's battery technology and beyond. Two-stage low voltage detection allows full LiPo compatibility, including powerful 11.1-volt 3S packs!
    • Innovative waterproof design
    • Three Programmable Drive Profiles:
      • Sport Mode - Forward / Brake / Reverse
      • Race Mode - Forward / Brake
      • Training Mode™ - 50% Forward / Brake / 50% Reverse (patent pending)
    • Integrated on/off switch
    • Traxxas EZ-Set® one-button setup
    • Large heat sink
    • High-efficiency MOSFET transistors
    • Auto-detects brushed, brushless, and sensored brushless motors
    • Built-in two-stage low-voltage detection for LiPo batteries
    • NiCad and NiMH battery packs: 4-9 cells (4.8 to 10.8 volts)
    • LiPo battery packs: 2-3 cells (7.4 to 11.1 volts)
    Velineon® 3500 Brushless Motor
    Extreme performance is standard equipment with the sensorless Velineon motor. Ultra high-temperature Neodymium magnets, high-speed ball bearings, and a precision balanced rotor deliver power and long life with near zero maintenance. Since there are no brushes or commutator to wear out, you always get the same blistering acceleration and ballistic top speed run after run.
    • Ultra high-temperature sintered Neodymium magnets
    • Optimized for power and efficiency in 1/10th scale vehicles
    • Consistent, high-power output, run after run
    • Low-maintenance, unique Traxxas design
    • Efficient, high-speed ball bearings
    • Precision-balanced rotor
    • Accessible solder tabs
    • Protective end cap
    • 10-Turn, 3500kV
    • Rebuildable
    • Hex hardware
    • Brilliant blue-anodizing finish
    • Silicon steel laminations
    • Delivers more power than comparable brushed motors
    • For more info about the Velineon 3500 Brushless motor click here
    Traxxas High-Current Connector
    The Velineon Power System doesn't waste power (or speed) on flimsy connectors. The patented Traxxas High-Current connector features gold-plated connectors in a virtually zero loss design that effortlessly funnels your battery's total power to the electronics to keep things running cool and at full capacity.
    Maxx Cable 12-Gauge Wire
    This super-flexible, high-current, low-resistance 12-gauge, wire acts like a series of giant pipes, flowing energy in and out of the electronic speed control. The Traxxas Connector combined with Maxx cable is a better engineered solution for extracting all the power your battery has to give.
    Hex Hardware
    Pro-quality, high-grade, metric hex-drive hardware is used throughout for extra strength, and easy maintenance and repair. The black-oxide rust-resistant finish provides a high tech look and feel.
    Rubber-Sealed Ball Bearings
    Precision 5x11mm rubber-sealed bearings offer the ultimate in super low-friction performance and maximum protection in dirty environments. They are used in all exposed locations on the car and are virtually maintenance free.
    Oil-Filled Ultra Shocks™
    High-speed on- and off-road action requires rugged, responsive shocks that can take abuse. Traxxas Ultra Shocks are proven tough as stock equipment for Traxxas Maxx trucks. The high-volume body yields large oil capacity, and a silicone bladder separates oil from air within the shock for consistent damping action, even during all-day off-road sessions. Dual X-ring seals give super-smooth performance without weeping or leaking, and Ultra Shocks are fully tunable with a wide range of oils, springs, and pistons.
    Digital High-Torque Waterproof Steering Servo
    Rally racing requires a powerful steering servo for responsive performance. The Traxxas 2075 digital high-torque, ball bearing steering servo comes standard for precision control, quick response, and unmatched torque—all in a waterproof case. Over 125 oz-in torque commands the Rally with authority, and the servo's 0.16-second speed turns your inputs into instant response at the wheels.
    Extruded Aluminum Driveshaft
    The Rally's center driveshaft is formed from extruded aluminum. There are no dogbones to wear, no drive cups to wobble. The extrusion process allows the shaft to be hollow and lightweight with internal splines that fit directly and securely onto the input shafts of the front and rear drive assemblies. The shaft runs perfectly straight and true and offers superior durability. Traxxas engineers highlighted this important innovation with vivid blue anodizing and a laser-etched Traxxas logo.
    Single-Screw Motor Access
    Inspired by the innovative E-Revo, Rally features a unique mount that holds the Velineon 3500 motor securely yet releases instantly with just one screw. Gear-mesh adjustments are fast and easy and the motor can be removed in just seconds.
    Revo-Spec® Differentials
    Race-proven in the 7-time National Champion Revo, Rally's differentials represent the state of the art in power handling and efficiency. Precision silicone gaskets and X-ring seals allow the diffs to be tuned for specific running conditions by varying the viscosity of the fluid inside them. Differential access for tuning is quick and easy. Just remove the front or rear cover and the entire differential slides right out. Rally let's you focus on having fun driving at the racetrack instead of being chained to the workbench scrambling through complex assemblies.
    Heavy-Duty Driveshafts
    Traxxas' telescoping, universal-joint driveshafts have evolved for even greater strength and articulation and are standard equiopment on the Rally. The U-joint driveshafts allow for maximum suspension movement and drivetrain efficiency, resulting in longer travel, tighter turning, and full power delivery. Extra material and fine-tuned design greatly increase torque handling. The shafts can also be used to upgrade the Slash 2WD and other Traxxas models!
    Revo®-Spec Torque-Control™ Slipper Clutch
    Another Traxxas exclusive, the Rally's patented slipper clutch design uses special semi-metallic friction material and finned aluminum alloy pressure plates to dissipate heat and provide consistent traction control. The slipper is easily adjusted without disassembly or removal, and the unique 3-pad design is proven rugged in Traxxas' most powerful electric and nitro vehicles. It's the perfect compliment to Velineon brushless power and 4WD, offering the ultimate in traction control.
    Heavy-Duty 32-Pitch Gears
    Extreme brushless horsepower is never an afterthought at Traxxas--we engineer every component with the demands of brushless power in mind. The Rally driveline is built to handle the full-power thrust of the Traxxas Velineon system and accommodate future power upgrades down the road. The spur gear's rugged 0.8 module/32-pitch teeth assure total reliability no matter how much power you pour on.
    Mamba Monster Compatible
    The Rally's low-CG chassis allows the massive Mamba Monster power system—which normally motivates trucks twice the weight of the Rally—to drop right in with no parts modification required. Overkill? Perhaps, but we can't resist going 80+mph. We don't think you'll resist either, so the drivetrain is built to handle the horsepower and speed.
    Long-Travel Suspension
    Unlike road-car rally conversions, the Traxxas Rally has huge amounts ultra-plush suspension travel that swallows up jumps and delivers incredible off-road control. All that travel gives Rally a truly authentic look and handling response that accurately simulates international rally racing, whether you're in the dirt or on the road. The fully-optimized front axle carrier is a result of computer modeling that allowed engineers to design for maximum articulation without binding or interference. Tight steering response is always there, even at the extreme ranges of the suspension travel. Double-shear tie rods and camber links simply can't pop off, so you always stay in control. Robust construction wards off crash damage, and oversized 10x15mm inboard bearings and 5x11mm outboard bearings are incredibly durable and smooth.
    Optimum-Geometry Steering
    with Integrated Servo Saver
    No part of Rally was overlooked in the quest for durability, precision, and performance. The dual-bellcrank design pivots on rubber-sealed ball bearings for smooth action in the harshest conditions, and an integrated cam-type servo saver protects the servo gears from crash impacts without sacrificing steering precision.
    Heavy-Duty 4mm Turnbuckles
    Rally's turnbuckles have broad flats that make it easy to set toe-in and camber. The tough steel construction is ultra durable and the captured rod ends won't pop apart during rigorous off-road pounding.
    Progressive Springs
    Progressive rate springs are lighter through the initial range of travel to maintain traction and composure over the usual track ruts and bumps. Hit the big jumps and the springs tighten up to prevent bottoming the chassis at the extreme ranges of the suspension travel.
    Officially Licensed BFGoodrich® tires
    Traxxas' attention to detail for Rally includes authentic, fully-licensed tire designs that replicate the actual racing rubber used on dirt or gravel rally circuits. The BFGoodrich® Rally Gravel tires offer superior traction on pavement, dirt, gravel, and more. The tire's unique directional tread pattern and sidewall design is captured in high-grip rubber, right down to the raised lettering on the sidewall.
    Rally 12-Spoke Wheels
    Equal parts style and strength, the new rally wheels feature a new 12-Spoke Rally Replica design color matched to the body style you choose. The wheels are molded in color (not painted) for scratch-proof good looks. Fully compatible with factory Traxxas and aftermarket tires, the new wheels also feature 12mm hexes and the same offset as Slash 4X4 wheels.
    ProGraphix Bodies
    Bold graphics, aggressive lines, authentic styling, and realistic proportions give the Rally a stunning look that is distinctly Traxxas. The body's crisp edges, flowing curves, and precise detailing perfectly suit the horsepower that lurks beneath. All you need to do is admire it; all the painting, decaling, and mounting is done for you. Traxxas is always Ready-To-Rac®!
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    [​IMG][​IMG]
    Rally (#7407) SPECSLength:21.7 Inches (552mm)Front Track:11.7 Inches (297mm)Rear Track:11.7 Inches (297mm)Center Ground
    Clearance:0.82 Inches (21mm)Weight:98.0oz (2.78kg)Height (overall):8.1 Inches (206mm)Wheelbase:12.8 Inches (324mm)Shock Length:Long (front), XXLong (rear)Tires:Officially-Licensed BFGoodrich® Rally Gravel
    2.2" Pre-Glued with Foam InsertsTire Diameter:4.02 Inches (102mm) (front and rear)Wheels (front/rear):2.2" 12-Spoke Rally Replica (White, Green, or Orange)Wheel Diameter:2.2 Inches (56mm) Outer
    3.0 Inches (76mm) InnerSpeed Control Type:VXL-3s™ Electronic Speed Control (waterproof)Motor (electric):Velineon® 3500 BrushlessOverall Drive Ratio:11.82 (stock, out-of-box)Differential Type:Hardened Steel Bevel, Sealed, Limited SlipGear Pitch:32Chassis Structure/Material:Molded Tub / Nylon CompositeDrive System:Shaft-Driven, Direct Drive 4WDSteering:Dual-Bellcrank with Integrated Servo SaverRadio System:TQi™ 2.4GHz 2-ChannelBody:Traxxas RallyTop Speed:60+mph*Skill Level:1Included Accessories:7-Cell 3000mAh NiMH (8.4 volts) Traxxas Power Cell Battery Pack and Charger, Precision Tool SetRequired Items:4 "AA" Batteries (for transmitter)*With optional gearing and 3S LiPo battery (items sold separately). 35+mph stock.[​IMG]
    RALLY SPEED & SKILL LEVEL CHARTSpeed:35+mph40+mph40+mph45+mph60+mphPinion/Spur:13/54*19/54**19/54**13/54*19/54**Battery:7-Cell NiMH7-Cell NiMH2S LiPo3S LiPo3S LiPoNominal Voltage:8.4V8.4V7.4V11.1V11.1VmAh:5000+ mAh4000+ mAh4000+ mAh5000+ mAh5000+ mAhSkill Level:12445*Stock Gearing ** Included optional gearing[​IMG]
    VXL-3s ESC SPECIFICATIONSInput Voltage:NiCad/NiMH 4-9 Cells (4.8 to 10.8 Volts DC);
    LiPo 2-3 Cells (7.4 to 11.1 Volts DC)Case Size:39mmW x 55mmD x 33mmHWeight:90 gramsMotor Limit (Brushed/Brushless):No motor limitOn Resistance Forward:0.00075 OhmsOn Resistance Reverse:0.00075 OhmsPeak Current - Forward:320APeak Current - Reverse:320ABraking Current:320AContinuous Current:200ABEC Voltage:6.0 VBEC Current:2.5A (with 6-cell NiMH)Power Wire:12-Gauge Maxx® CableInput Harness Wire:26 Gauge / 100mmTransistor Type:MOSFETLow Voltage Detection:2-Stage indicators, switchable (on or off)Thermal Protection:2-Stage thermal shutdownProfile selection:Sport Mode:
    100% FWD, 100% BRAKES, 100% REV
    Race Mode:
    100% FWD, 100% BRAKES, NO REV
    Training Mode:
    50% FWD, 100% BRAKES, 50% REVSingle-Button Setup:Yes, Traxxas EZ-Set®Battery Input Connector :Traxxas High-Current ConnectorMotor Types (Autodetect):Brushed, brushless, sensored brushlessPorts:RX Input, motor sensor, auxiliary fanFor full details, click here.*Properly geared
    Laatst bewerkt: 9 okt 2012
  2. Scaler
    Scaler
    3 nov 2011
    Excuus. Zag te laat dat er al een topic over deze auto gestart was.
    traxxas-rally-1-10-a
    Deze maar dicht dan...toch?
    Laatst bewerkt door een moderator: 19 nov 2015
  3. Klamath
    Klamath
    3 mrt 2008
    Westerhaar, Overijssel
    Vind dit topic een stuk beter om eerlijk te zijn. (Beginpost is erg zinnig ipv alleen een plaatje. :) )
    Deze gaat er hier waarschijnlijk wel van komen iig. (maar dan word 't VXL setje wel vervangen door een MMP met 550 motor.)
  4. Scaler
    Scaler
    3 nov 2011
    Volgens mij heb je Traxxas ooit eens gecontact over jouw 1:10 ontwerp.....Heb alleen nog geen credits gezien jouw kant op bij de specs ofzo:D
  5. Klamath
    Klamath
    3 mrt 2008
    Die van mij was ook op basis van de 1/10 Revo, dit is uiteraard totaal wat anders. :lol:
    Maar vind hem wel leuk uitzien om eerlijk te zijn.
    Zou er wel 1/8 buggy wielen onder zetten om niet van die balonbanden op een on-road auto te hebben. (hoop dat de 1/8 Rally een goede start maakt, en de oude Rally game bandjes weer komen. :D )
    Ben iig erg benieuwt of dit chassis net zo'n probleemkind is als de Slash 4x4. Moet ik er wel meteen bij zeggen dat je met deze auto weer net niet daar kunt rijden waar de 4x4 erg veel problemen had bij mij.. diep mul zand.
    Ben iig erg benieuwt.
  6. Ruy Horta
    Ruy Horta
    3 jan 2011
    Amstelveen
    Hopelijk start Traxxas hiermee een de echte rally rage, want mooie 1/8 rally (buggy maten) zie je nog weinig en ze zijn over het algemeen duur.
    De auto zelf is een leuke mix van Slash 4x4 & Stampede 4x4 met wat nieuwe onderdelen. Typische Traxxas efficiency. Ik zie tzt wel ruimte voor deze Rally als roller om mee te rommelen.
    Ik snap echter niet waarom Traxxas de auto niet standaard met sway bars levert, ook al ligt hij lager dan een Slash.
    Verder, laat maar komen :)
  7. motorsports
    motorsports Forum veteraan
    16 mrt 2006
    rondom Utrecht
    Neu , deze heeft een goede informatieve begin post .;) en is ook meer op zijn plaats in dit sub forum.
  8. Pete®tje
    Pete®tje
    30 jan 2011
    Rotterdam
    Traxxas geeft aan dat het een "multi-terrain" auto is. Dus hij hoort of in beide subforums of in geen van beide.
  9. motorsports
    16 mrt 2006
    rondom Utrecht
    Prima!,wat meer moeite in je startpost qwa info, en hoppa, kunnen we twee draadjes volgen over dezelfde auto in verschillende sub forum's..:-|
  10. Scaler
    Scaler
    3 nov 2011
    Volgens Wikipedia is een Rally een meerdaagse reeks van proeven op de openbare weg. In die zin zou de auto dus on-road wezen. Traxxas presenteert de auto echter als off-road...
    [URL=" 1/10 Rally - 4WD Performance, Multi-Terrain Versatility, Velineon Power! - YouTube[/URL]
    Eerlijk gezegd heb ik de gedachte dat de meeste gebruikers hier de Rally zullen beschouwen als een off-road auto. Vandaar de startpost in dit subforum. Of zullen we een "multi terrain" subforum starten:evil:;)
    On Topic: Relaese datum in the States. 17 oktober. Verwachte prijs 449 Dollar (als ik het wel heb)
    Review RCCaraction.
    [media=youtube]tSq4-_Us77o[/media]
    We hebben allemaal de auto nog niet in het echt gezien, maar in deze review is m.i. te zien dat het niet zomaar een nieuw chassis is die tussen Slash/Stampede 4x4 delen is geplakt. De bodem van de Rally is vlak, dus de gearboxen/skids e.d. lijken nieuw ontworpen. De aandrijflijn bestaat wel uit dezelfde delen als die van de 4x4 Slash/Stampede. Hoop wel dat er spoedig blanco body's/verschillende body's op de markt komen
  11. drift-junkie
    drift-junkie
    22 jan 2005
    Rally proeven worden gehouden op zowel verharde als onverharde paden, wegen en terreinen, sommige rally’s rijdt men zelfs, waar helemaal geen (aangegeven) wegen zijn, denk aan bv de woestijnrally’s…..
    ”openbaar wegen voor voertuigen”???, niet alle proeven of bepaalde sectoren daarvan, worden op openbaren terreinen, paden of wegen verreden…denk aan bospaden, militaire terreinen, particulieren wegen..enz
    Rallycross = 60% verhard/40% onverhard op een afgesloten circuit
    on-road/off-road > verhard/onverhard….multi-terrain...
  12. Scaler
    Scaler
    3 nov 2011
    Mr Rallycup has spoken:D
  13. Pete®tje
    Pete®tje
    30 jan 2011
    Rotterdam
    Het maakt mij niet zoveel uit of er nu een, twee of zes topics over de Rally worden gestart. De reden dat ik die post niet in off-road heb gezet, is dat Traxxas hem een multi-terrain auto noemt. Wat Wikipedia ervan vindt, boeit me niet zo. En een nieuw ontworpen gearbox lijkt me interessant, want die zit er niet op.
    Je kan er heel ingewikkeld over doen, maar er zijn wel 9 onderdelen verschillend ten opzichte van de Slash 4x4. Dus een betiteling als "Slash met andere body en LCG chassis" is helemaal niet zo raar.
    In mijn start topic staat een verwijzing naar Traxxas.com waar alles is te vinden over de auto. Copy & paste werk vind ik dan niet zo zinvol.
    Oh, en "presenteerd" is geen Nederlands.
  14. Klamath
    Klamath
    3 mrt 2008
    Tja, op die manier kun je een Seat Leon en een Audi A3 ook wel een Golf noemen. meeste technische delen zijn ook hetzelfde.
    Maar zonder gein, Ben het er wel mee eens. veel dingen zijn overgenomen.
    Wat ze echter weer wel doen is hierdoor een totaal anders rijdende auto maken, waarvan de slijtage delen goedkoop te produceren zijn omdat de seriegrootte gewoon groot is. (de differentiëlen zijn immers hetzelfde als de andere 4x4 modellen, welke wederom hetzelfde zijn als van de E-Maxx en E-Revo. )
    Ik ben er in ieder geval wel een voorstander van, gezien het de prijs een beetje drukt. (kijk maar naar de prijs van HPI of Kyosho onderdelen in relatie tot de Traxxas delen. dan wist ik het ook wel. :) )
    Kan zelf iig niet wachten tot de eerste Reviews binnen komen. Heb nog een setje Big-Bore schokbrekers liggen, dus de zwakke plek van de traxxas auto's zou ik al meteen weg kunnen halen. :D
    Ben benieuwt.
  15. Scaler
    Scaler
    3 nov 2011
    Dank U...Gewijzigd.
    Tja.. Het is net Lego. Dezelfde onderdelen, maar steeds iets anders.
    Ondanks dat de Rally deels uit reeds beproefde onderdelen bestaat, vind ik het rijbeeld van deze auto erg mooi om te zien. Minder "buggyachtig" als andere 4x4 auto's...
    Hier gaat de Rally er gewoon komen. Benieuwd naar de prijzen in Europa.
  16. Klamath
    Klamath
    3 mrt 2008
    Heb nog een Novak 4.5T HV (5000kv, en mag op 4s Lipo. :shock:) motortje liggen en een MMP. dus als roller zien te fixen, en word 't lachen geblazen. Leuke setup om dan op 3s lipo te gaan rijden. :)
    Ik vind hem iig leuk uit zien. vind zelfs de kap wel wat hebben. (is eens wat anders)
  17. Pete®tje
    Pete®tje
    30 jan 2011
    Rotterdam
    Ik blijf het grappig vinden dat er een Castle Mamba Monster set als upgrade in de Parts List staat.
    Misschien wacht ik tot de onderdelen een beetje los te koop zijn en dan pruts ik er zelf een in elkaar.
    Een complete auto in NL kopen blijft toch een kostbare bedoeling.
  18. Auto-G
    Auto-G
    26 feb 2011
    "De reden dat ik die post niet in off-road heb gezet, is dat Traxxas hem een multi-terrain auto noemt. Wat Wikipedia ervan vindt, boeit me niet zo."
    Niet echt belangrijk maar de logica ontgaat me.
    Hoezo is het zo boeiend hoe traxxas hem noemt en niet wat wikipedia zegt?
    Traxxas noemt de erevo toch ook 1/10 kan je moeilijk serieus nemen toch?
    Wat mij betreft zijn al mn offroad wagens 'Multi Terrain Autos' trouwens.
    Denk niet dat mn 1/8 buggy het minder doet op de straat als dit ding
    Waar die nou wel of niet moet staan heb ik zelf trouwens niet echt een mening over :p
    Maar ik zou zelf meer waarde hechten aan normale standaarden en common sense dan het traxxas marketing verhaal
    Wel een cool model opzich eindelijk weer een traxxas met een beetje redelijke COG
    De meeste andere modellen hebben vaak een verschrikkelijk hoog zwaartepunt en niet meer bodemvrijheid dan vergelijkbare modellen met een veel lager zwaartepunt zoals de slash en de stampede
  19. Pete®tje
    Pete®tje
    30 jan 2011
    Rotterdam
    Als je een Traxxas Rally multi-terrain auto hebt gekocht zoek je voor ondersteuning niet in het off-road gedeelte van een forum lijkt me. Dan gaat het om de Traxxas Rally en niet om de omschrijving die Wikipedia voor Rally heeft.
    Op die manier zou ik voor mijn Stampede op een forum over runderen terechtkomen en met mijn Bandit bij criminelen.
    Ik rijd met al mijn Traxxas auto's het meest op straat, maar kijk in het off-road forum for mijn Rustler/Bandit, Stampede en Merv. In het on-road stuk vind ik alleen de Mustang.
    Maar goed, je kunt er eindeloos over discussieren.
  20. Auto-G
    Auto-G
    26 feb 2011
    Denk je verkeerd had begrepen wat ik zei.
    "Als je een Traxxas Rally multi-terrain auto hebt gekocht zoek je voor ondersteuning niet in het off-road gedeelte van een forum lijkt me.
    Op die manier zou ik voor mijn Stampede op een forum over runderen terechtkomen en met mijn Bandit bij criminelen."
    Ik begrijp hieruit dat jij vind dat het meer in onroad thuis hoort, daar heb ik zelf niet echt een mening over en wil ik me opzich niet in mengen.
    De rest van dat comment slaat helemaal nergens op lees het zelf nog maar een keer na.
    Wat je op het laatst aanhaalt over het zoeken van Stampede of Bandit op wikipedia. dat zijn geen auto types he? :) daarbij vraag ik me dan af of je denkt dat ik gek ben of het je 2e dag op het internet is :p
    Voor de duidelijkheid:
    Enkel wou ik aangeven dat ik het zeer onlogisch vind om af te gaan op een marketing verhaaltje van een fabrikant met een track record van onzin claims om te bepalen wat iets is en waar het hoort.
    Dit omdat fabrikanten traditioneel graag doen alsof ze het wiel opnieuw hebben uitgevonden en op elk schroefje een label willen plakken omdat het op die manier specialer lijkt.
    Waar die info wel vandaan moet komen is heus niet perse wikipedia hoor, daarom zei ik ook algemene standaarden en common sense lijken me waardevoller dan een of ander marketing verhaal.
    Of het wel of niet correct is betwist ik niet.
    Grts
