Voor de Spektrum vliegers onder ons weer een leuk nieuwtje.
Ontvanger en BeastX in 1.
Hier de specs:
Key Features
BeastX flybarless technology is the most powerful, easiest-to-use flybarless technology flying today. And now with the amazing AR7200BX, you can add it to your 250- to .90-size helicopter while saving space and reducing flying weight at the same time. The groundbreaking Spektrum innovation combines a 7-channel DSMX receiver with a BeastX, 3-axis MEMS stabilization system into a single, compact unit. Besides eliminating the mechanical complexity of a flybar, the BeastX technology built into the AR7200BX lets you quickly fine-tune stability, cyclic response and tail response without touching a single linkage or require special software, All you need is your DSM2/DSMX transmitter and this unit.
Groetjes,
Eric
Hier de specs:
Key Features
- Integrated BeastX 3-axis MEMS gyro
- 250 to 800 sized helicopters
- Designed for easy access for field adjustments
- DSMX safety and control
- Flight log telemetry compatible
- 11ms frame rate
- 2048 resolution
Groetjes,
Eric
