CVT Automatic Transmission for Tamiya Trucks
A continuously variable transmission (CVT) (also known as a single-speed transmission) is an automatic transmission that can change seamlessly through an indefinite number of effective gear ratios between maximum and minimum values. This contrasts with other mechanical transmissions that offer a fixed number of gear ratios. The flexibility of a CVT allows the input shaft to maintain a constant angular velocity.
Specifications:
Surface Treatment: None
Processing Method: Die Cast
Material: Zinc Alloy
Reduction Ratio: 1:61.44 (Max); 1:9.83 (Min)
Gear Ratio: 1:24.57
Pulley Ratio: 1:2.5 Start, 2.5:1 maximum Rotating Speed
Recommended Brushed Motor: 12V540 Brushed Motor 27T~35T; Rotating Speed Range: 13200-16500 turn/MIN
Recommended Brushless Motor: 12V540 Brushless Motor 1300KV~1500KV; Rotating Speed Range: 15000-18000 turn/MIN
Output Shaft Diameter: 0.19in / 5mm; Length: 0.23in / 6mm
Mounting Holes: Chassis Direction X(2.16in / 55mm); Axle Direction Y(2.08in / 53mm)
Transmission Length: 4.33in / 110mm
Mounting the Motor total Length: 6.37in / 162mm
Weight: 26.17oz / 742g
Designed to fit Tamiya 1/14 Semi Truck or Custom Project
http://store.rc4wd.com/EcoDrive-114...ission-for-Tamiya-114-Semi-Trucks_p_4897.html
Specifications:
Gear Ratio: 1:24.57
