geen verbinding met cleanflight
Discussie in 'FPV (First person view)' gestart door malibucola, 29 feb 2016.
  1. malibucola
    malibucola
    4 feb 2011
    hoofddorp
    Hoi Hoi
    heb het even in het Engels gedaan, wand ik ben momenteel erg wanhopig [​IMG] [​IMG] [​IMG] [​IMG]
    zo kan ik het bij iedereen uit leggen .
    problems whit flashing cleanflight:
    1* Naze32 bootpins shortened ,(reboot)
    Wen: button on in cleanflight.
    No reboot sequens
    Flash on connect
    thenLoad firmware, then comet the naze32. = Bleu light on - no flickering.
    than response from cleanflight !!!
    2016-02-29 @ 17:16:53 -- Running - OS: Windows, Chrome: 48.0.2564.116, Configurator: 1.2.1
    2016-02-29 @ 17:18:23 -- Detected: COM3 - triggering flash on connect.
    [/color]
    Noting happened !!!, when enter flash.
    no response from bootloader-programing failer !
    2* naze32 no boot pins shortened:
    Wen naze32 connecting to computer, Lights bleu/orange all flickering
    open clean flight:
    2016-02-29 @ 17:15:46 -- Running - OS: Windows, Chrome: 48.0.2564.116, Configurator: 1.2.12016-02-29 @ 17:16:06 -- Serial port successfully opened with ID: 8
    2016-02-29 @ 17:09 -- Failed to open serial port
    2016-02-29 @ 17:16:16 -- No configuration received within 10 seconds, communication failed
    I download CP210x drivers.
    I did re COM3 with : hercules_3-2-8.exe
    and i did STMFlashLoaderDemo
    but with STMFlashLoaderDemo,
    also message:
    No response from the target, the boot Loader can not be stared
    Please, verify the boot mode configuration and flash protection status.
    Reset your device then try again ..
