kj66 upgrade
Discussie in 'Zelfbouw turbines' gestart door jetflydemoteam, 10 feb 2012.
  1. jetflydemoteam
    jetflydemoteam
    20 dec 2011
    Reading on this forum i decided to change the diffusor on old 1999 kj66
    after failure..
    soon test on stand
    Jetflydemoteam - Home page
  2. jetflydemoteam
    jetflydemoteam
    20 dec 2011
  3. frema
    frema
    7 feb 2007
    Sint-Maartensdijk
    yes i know
    this diffusor is letting more air through
    thats all
    the flame likes air
    if he gets it right , then the engine will realy like it.
    good job
  4. Gerald Rutten
    Gerald Rutten
    6 mei 2005
    Zuidelijk
    Hi Christian, nice to see you here! Good looking diffuser you made there. I have a similar diffusor for the KJ66 drawn in autocad, not tried yet. Did you simply extend the existing original wedges or did you change geometry slightly? Curious on how you calculated outflow area.
    Best regards,
    Gerald
  5. jetflydemoteam
    jetflydemoteam
    20 dec 2011
    ciao Gerald...
    i simply extended the original wedges...like your drawing (the cnc radius is according to the tools available)
    i added n.3 hole for bearing cooling.......an reworked the compressor cover to reduce gap
    then all seem to be good.. :)
