Ik wilde een algemeen topic maken voor de Ez serie`s.
Ik rij zelf de sandmaster alweer 4maanden lang, weinig brokken mee gehad alleen een keer de counter gears de tanden eraf.
Mijn sandmaster rij nu met een Tamiya Superstock TZ borstel moter.
Verbetering wat ik heb aan gebracht kun je in deze link vinden.
www.modelbouwforum.nl/forums/bouwverslagen-autos/202592-kyosho-sandmaster-project-verhogen.html
In dit forum kunnen we algemeen over de Ezrun praten, over verbeteringen die aangebracht zijn of als je wilt showen hoe die eruit ziet.
Hier onder de standaard specs met verhaaltje
Sandmaster
Nexxt
Axxe
The perfect introduction to real R/C buggy action!
True racing buggy performance has never been easier to enjoy!
Spray dirt as you fly over bumps and jumps! The Sandmaster’s retromodern form responds obediently to every command input! Kyosho’s knowledge in R/C buggy design accumulated over so many years has been applied to produce the ultimate beginner racing buggy. Fully factory assembled in a Readyset package, this is the definitive beginner R/C buggy for performance and price.
Motor can be removed with just 2 screws and backlash requires no adjustment. Gear ratio can be changed (with aftermarket gear) by loosening 2 screws. Incorporates high durability diff gears and realizes a long maintenance cycle.
Battery pack can be changed through the hatch on the underside of the chassis. One touch releases the lock for reliable and easy access.
Retromodern body form features snap-on panel structure. Easy to attach and remove for maintenance. Additional colors (sold separately) allow customization.
Bead lock style wheels feature separate tire mounting section. No glue is required when replacing tires. Simply tighten screw to secure. Tires deliver exceptional dual purpose performance.
Double wishbone suspension is equipped with friction shocks. Dial adjustment allows chassis height to be changed is available.
2.4GHz Perfex KT-200 R/C system features full setting functionality and removes the need to manage frequency bands. Equipped with pre-set ESC so is able to start as soon as power is switched on.
Includes ORION battery and charger.
YSZJ0DN1gOE[/media] New Sand Master EZ KYOSHO (2012 edition) - YouTube
< ReadySet Contents >
Factory assembled chassis with R/C unit installed
Pre-assembled body with decals applied
Perfex KT-200 transmitter
Cross wrench
7.2V-1800mAh NiMH battery
Charger
Length
395mm
Width
245mm
Height
140mm
Wheelbase
270mm
Tread (F/R)
190mm / 190mm
Tire(F/R)
Φ86mm × 32mm / Φ86mm × 32mm
Gear Ratio
8.76 : 1
Weight
1,500g (approx.)
Motor
22-turn 540-type
R/C System
Perfex KT-200
Sandmaster
Nexxt
Axxe
Cross wrench
Charger
Length
395mm
Width
245mm
Height
140mm
Wheelbase
270mm
Tread (F/R)
190mm / 190mm
Tire(F/R)
Gear Ratio
8.76 : 1
Weight
1,500g (approx.)
Motor
22-turn 540-type
R/C System
Perfex KT-200
