P13/F13 en P15/F15 programmavoorstellen
Discussie in 'F3A' gestart door Henri Zikken, 12 apr 2010.
  1. Henri Zikken
    Henri Zikken Guest
    Ga maar vast oefenen :p
    Dit zijn dus nog niet de definitieve programma's, maar voorstellen:
    Prelimenary Schedule P-13 (2012-2013)
    P-13.01 Clover Leaf with horizontal roll
    From upright, pull through a ¼ loop into a vertical upline, push through a ¾ loop into a horizontal line, perform a roll, push through a ¾ loop into a vertical downline, pull through a ¼ loop, exit upright.
    P-13.02 Stall Turn with ¼ roll up, ¼ roll down
    From upright, pull through a ¼ loop into a vertical upline, perform a ¼ roll, perform a stall turn into a vertical downline, perform a ¼ roll push through a 1/4 loop, exit inverted.
    P-13.03 Roll Combination with three ¼ rolls, three ¼ rolls in opposite direction
    From inverted, perform three ¼ rolls followed by another three ¼ rolls in opposite direction, exit inverted.
    P-13.04 Half Square Loop with two ½ rolls in opposite directions
    From inverted, push through a ¼ loop into a vertical upline, perform two ½ rolls in opposite directions, push through a ¼ loop, exit upright.
    P-13.05 Triangle with roll in each line
    From upright, push through a 1/8 loop into a 45° downline, perform a roll, push through a 3/8 loop into a horizontal line, perform a roll, push through a 3/8 loop into a 45° upline, perform a roll, push through a 1/8 loop, exit upright.
    P-13.06 Reverse Immelman with roll
    From upright, perform a roll and immediately push through a ½ loop, exit inverted.
    P-13.07 45° Upline with 1 ½ snap roll
    From inverted, push through a 1/8 loop into a 45° upline, perfrom 1 ½ snap roll, push through a 1/8 loop, exit upright.
    P-13.08 Reverse Top Hat with ¼ roll down, ¾ roll up
    From upright, push through a ¼ loop into a vertical downline, perform a ¼ roll, push through a ¼ loop into a horizontal line, push through a 1/4 loop into a vertical upline, perform a ¾ roll, push through a ¼ loop, exit upright.
    P-13.09 Spin with 2 ½ turns, 2 ½ turns in opposite direction
    From upright, perform a spin with 2 ½ turns immediately followed by another 2 ½ turns in the opposite direction, perfrom a vertical downline, pull through a ¼ loop, exit upright.
    P-13.10 Pull-Push-Pull Humpty-Bump with ¼ roll up, ¼ roll down (Option: Two ¼ rolls up)
    From upright, pull through a ¼ loop into a vertical upline, perform a ¼ roll, push through a 1/2 loop into a vertical downline, perform a ¼ roll, pull through a ¼ loop, exit upright.
    Option: From upright, pull through a ¼ loop into a vertical upline, perform two ¼ rolls, push through a 1/2 loop into a vertical downline, pull through a ¼ loop, exit upright.
    P-13.11 Cuban 8 with integrated rolls on top 90° of both part loops.
    From upright, pull through a 5/8 loop into a 45° downline while performing an integrated roll in the top 90° of the loop, push through a ¾ loop into another 45° downline while performing a roll in the top 90° of the loop, pull through a 1/8 loop, exit upright.
    P-13.12 ½ Loop
    From upright, pull through a 1/2 loop, exit inverted.
    P-13.13 Square Loop with ½ roll in each line
    From inverted, pull through a ¼ loop into a vertical downline, perform a ½ roll, push through a ¼ loop into a horizontal line, perform a ½ roll, pull through a ¼ loop into a vertical upline, perform a ½ roll, push through a ¼ loop into a horizontal line, perform a ½ roll , exit inverted.
    P-13.14 Figure 9
    From inverted, push through a ¾ loop into a vertical downline, perform two ½ rolls, pull through a ¼ loop, exit upright.
    P-13.15 Roll Combination with ½ roll, roll, ½ rolls in opposite directions
    From upright, perform a ½ roll followed by a roll in opposite direction, followed by another ½ roll in again opposite direction, exit upright.
    P-13.16 ½ Loop on Corner with ¼ roll, ¼ knife-edge loop, ¼ roll from upright pull through a 1/8 loop into a 45° upline, perform ¼ roll, perform ¼ knife-egde loop into a 4 45° upline, perform ¼ roll, pull through a 1/8 loop, exit inverted.
    P-13.17 Figure Z with four 1/8 rolls
    From inverted, pull through a 3/8 loop into a 45° downline, perform four 1/8 rolls, pull through a 3/8 loop, exit upright.
    Final Schedule F-13 (2012-2013)
    F-13.01 Humpty-Bump with ¾ roll up, ½ knife-edge loop, ¾ roll down
    From upright, pull through a ¼ loop into a vertical upline, perform a ¾ roll, perform a ½ loop in knife-egde flight into a vertical downline, perform a ¾ roll, push through a ¼ loop, exit inverted.
    F-13.02 ½ 6-Sided Loop with ½ roll
    From inverted, pull through a loop while performing four ¼ rolls, integrated in each 90° of the loop, exit inverted. into a 30° upline, push through a 1/6 loop into a vertical upline, perform a ½ roll, pull through a 1/6 loop into a 30° upline, pull through a 1/12 loop, exit inverted.
    F-13.03 Loop with four ¼ rolls integrated
    F-13.04 Figure 6 with stall turn, two ¼ rolls down
    From inverted, push through a ¾ loop into a vertical upline, perform a stall turn into a vertical downline, perform two ¼ rolls, pull through a ¼ loop, exit upright.
    F-13.05 Horizontal Circle 8 with two rolls
    From upright, perform a ¼ horizontal circle while performing the first ¼ of two rolls to the outside, then while continuing the rolling (¼ of the rolls per ¼ of the circles), then perform immediately another (full) circle in the opposite direction, then while continuing the rolling accordingly finish the remaining ¾ of the first circle, exit upright.
    F-13.06 Pull-Push-Push Humpty-Bump with four ¼ rolls up, roll down
    From upright, pull through a ¼ loop into a vertical upline, perform four ¼ rolls, push through a ½ loop into a vertical downline, perform a roll, push through a ¼ loop, exit inverted.
    F-13.07 Roll Combination with ¼ roll, two snap rolls in opposite directions, ¼ roll
    From inverted, perform a ¼ roll followed by a snap roll and another snap roll in opposite direction, followed by a ¼ roll, exit upright.
    F-13.08 Shark Fin with roll up, two ¼ rolls down
    From upright, pull through a 1/8 loop into a 45° upline, perform a roll, push through a 3/8 loop into a vertical downline, perform two ¼ rolls, exit upright.
    F-13.09 45° Upline with eight 1/8 rolls
    From upright, pull through a 1/8 loop into a 45° upline, perform eight 1/8 rolls, exit upright.
    F-13.10 Reverse Top Hat with ¾ roll down, ¼ rolls up (Option: roll down, two ¼ rolls up)
    From upright, push through a ¼ loop into a vertical downline, perform a ¾ roll, push through a ¼ loop into a horizontal line, push through a ¼ loop into a vertical upline, perform a ¼ roll, push through a ¼ loop, exit upright.
    Option: From upright, push through a ¼ loop into a vertical downline, perform a roll, push through a 1/2 loop into a horizontal line, push through a ¼ loop, perform two ¼ rolls, exit upright.
    F-13.11 Clown Dance with ½ loop, inverted spin, 2 ½ turns, two ¼ rolls down
    From upright, pull through a 1/2 loop into a horizontal line, perform an inverted spin with 2 ½ turns, perform a vertical downline, perform two ¼ rolls, exit upright.
    F-13.12 Fighter Turn with two ¼ rolls
    From upright, pull through a 1/8 loop into a 45° upline, perform a ¼ roll, push through ½ circle, to a 45° downline, perform a ¼ roll, pull through a 1/8 loop, exit upright.
    F-13.13 Knife-Edge Loop with integrated ½ roll on top 90°
    From upright, perform a ¼ roll, perform a loop in knife-edge flight while performing a ½ roll integrated in the top 90° of the loop, perform a ¼ roll, exit upright.
    F-13.14 Reverse Cuban 8 with sanp roll up
    From upright, pull through a 1/8 loop into a 45° upline, perform a snap roll, push through a 5/8 loop, exit inverted.
    F-13.15 Triangle with two ¼ rolls in each line
    From inverted, push through a 3/8 loop into a 45° upline, perform two 1/4 rolls roll, pull through a ¼ loop into a 45° downline, perform two ¼ rolls, push through a 3/8 loop into a horizontal line, perform two ¼ rolls, exit upright.
    F-13.16 ½ Loop with roll integrated
    From upright, pull through a ½ loop, while performing a roll integrated, exit upright.
    F-13.17 45° Downline with ¼ roll, roll, ¼ roll in opposite directions
    From inverted, pull through a 1/8 loop into a 45° downline, perform ¼ roll followed by a roll in opposite direction followed by a another ¼ roll in opposite direction, pull through a 1/8 loop, exit upright.
    Prelimenary Schedule P-15 (2014-2015)
    P-15.01 Golf Ball with two ½ rolls
    From upright, pull through a 1/8 loop into a 45° upline, perform a ½ roll, push through a ¾ loop into a 45° downline, perform a ½ roll, pull through a 1/8 loop, exit upright.
    P-15.02 ½ Square Loop on Corner with ½ roll
    From upright, pull through a 1/8 loop into a 45° degree upline, pull through a ½ loop into a 45° upline, perform a ½ roll, push through a 1/8 loop, exit upright.
    P-15.03 Double Immelman with two knif-edge flights
    From upright push through a ½ loop immediately followed by a ¼ roll, perform a horizontal knife-edge flight, perform a ¼ roll and immediately pull through a ½ loop immediately followd by a ¼ roll, perform a horizontal knife-edge flight, perform a ¼ roll, exit upright.
    P-15.04 Half Square Loop with ½ roll
    From upright push through a ¼ loop, perform a ½ roll, pull through a ¼ loop, exit upright.
    P-15.05 Stall Turn with 1 ¼ roll up, ¾ roll down
    From upright, pull through a ¼ loop into a vertical upline, perform a 1 ¼ roll, perform a stall turn into a vertical downline, perform a ¾ roll down, pull through a ¼ loop, exit upright.
    P-15.06 Reverse Cuban 8 with ½ roll
    From upright pull through a 1/8 loop into a 45° upline, perform a ½ roll, pull through a 5/8 loop, exit upright.
    P-15.07 Roll Combination with three 1/6 rolls, three 1/6 rolls in opposite direction
    From upright, perform three 1/6 rolls followed by another three 1/6 rolls in opposite direction, exit upright.
    P-15.08 Pull-Push-Push Humpty-Bump with ¾ roll up, ¾ roll down (Option: ½ roll up, ½ roll down)
    From upright, pull through a ¼ loop into a vertical upline, perform a ¾ roll, push through a ½ loop into a vertical downline, perform a ¾ roll, push through a 1/4 loop, exit inverted.
    Option: From upright, pull through a ¼ loop into a vertical upline, perform a ½ roll, push through a ½ loop into a vertical downline, perform a ½ roll, push through a 1/4 loop, exit inverted.
    P-15.09 Top Hat Inverted Spin with 2 ½ turns
    From inverted push through a ¼ loop into a vertical upline, pull through a ¼ loop into a horizontal line, perform a spin with 2 ½ turns, perform a verical downline, pull through a ¼ loop, exit upright.
    P-15.10 Pull-Knife-Edge-Push Humpty-Bump with ½ roll down
    From upright, pull through a ¼ loop into a vertical upline, perform a 1/2 loop in knife-edge flight into a vertical downline, perform a ½ roll, push through a ¼ loop, exit inverted.
    P-15.11 Reverse Cuban 8 with two ½ rolls, two ½ rolls in opposite directions
    From inverted, push through a 5/8 loop into a 45° downline, perform two ¼ rolls, push through a ¾ loop into another 45° downline, perform two ½ rolls in opposite directions, pull through a 1/8 loop, exit upright.
    P-15.12 Figure 9 with four ¼ rolls up
    From upright, pull through a ¼ loop into a vertical upline, perform four ¼ rolls, perform a ¾ loop, exit inverted.
    P-15.13 Hour-Glass with ½ roll, roll, ½ roll
    From inverted, push through a 1/8 loop into a 45° upline line, push through a 3/8 loop into a horizontal line, perform a ½ roll, pull through a 3/8 loop into a 45° downline, perform a roll, push through a 3/8 loop into a horizontal line, perform a ½ roll, pull through a 3/8 loop into a 45° upline, pull through a 1/8 loop, exit inverted.
    P-15.14 Half Square Loop on Corner with ½ rolls in each line
    From inverted, pull through a 1/8 loop into a 45° downline, perform a ½ roll, push through a ¼ loop into a 45° downline, perform a ½ roll, pull through a 1/8 loop, exit upright.
    P-15.15 45° Upline with two rolls in opposite directions
    From upright, pull through a 1/8 loop into a 45° upline, perform two rolls in opposite directions, push through a 1/8 loop, exit upright.
    P-15.16Reverse Immelman with ½ roll
    From upright, perform a ½ roll and immediately pull through a ½ loop, exit upright.
    P-15.17 Avalache with snap roll on top
    From upright, pull through a loop while performing a snap roll on the top of the loop, exit upright.
    Final Schedule F-15 (2014-2015)
    F-15.01 Double Immelman with ½ rolls in both ½ loops integrated, two ½ rolls in opposite direction
    From upright, pull through a 1/2 loop while performing a ½ roll integrated, immediately followed by a ½ roll in opposite direction, perform a horizontal line, pull through a ½ loop while performing a ½ roll, immediately followed by a ½ roll in opposite direction, exit upright.
    F-15.02 Stall Turn with three ¼ rolls up, 1 1/14 rolls down
    From upright, pull through a ¼ loop into a vertical upline, perform three ¼ rolls, perform a stall turn into a vertical downline, perform 1 ¼ roll, exit inverted.
    F-15.03 Golf Ball with two ¾ roll up, knife-edge loop, ¾ roll down
    From inverted, pull through a 1/8 loop into a 45° upline, perform a ¾ roll perform a ¾ loop in knife-edge flight into a 45° downline, perform a ¾ roll, pull through a 1/8 loop, exit upright.
    F-15.04 ½ Square Loop with two snap rolls in opposite directions
    From upright, pull through a ¼ loop into a vertical upline, perform a snap roll and another snap roll in opposite direction, pull through a ¼ loop, exit inverted.
    F-15.05 Loop with two ½ rolls in opposite directions integrated
    From inverted, pull through a loop while performing a ½ roll integrated in the first 180° of the loop, immediately followed by a ½ roll in opposite direction integrated in the second 180° of the loop, exit inverted.
    F-15.06 Inverted Spin with 2 ½ turns, ½ roll down
    From inverted, perform an inverted spin with 2 ½ turns, perform a vertical downline, perform ½ roll down, exit upright.
    F-15.07 Horizontal Triangular Circle with ¼ roll, ½ outside rolls in each corner integrated
    From upright, perform a ¼ roll, perform a horizontal triangular circle of equal side lengths while performing a ½ roll to the outside in each corner integrated, perform a ¼ roll, exit upright.
    F-15.08 Top Hat with two ¼ rolls up, snap roll down (Option: Three ¼ rolls up, 1 ¼ snap roll down)
    From upright, pull through a ¼ loop into a vertical upline, perform two ¼ rolls, pull through a ¼ loop into a horizontal line, pull through a ¼ loop into a vertical down line, perform a snap roll, pull through a ¼ loop, exit upright.
    Option: From upright, pull through a ¼ loop into a vertical upline, perform three ¼ rolls, pull through a ¼ loop into a horizontal line, pull through a ¼ loop into a vertical down line, perform a 1 ¼ snap roll, pull through a ¼ loop, exit upright
    F-15.09 Vertical Cuban 8 with four 1/8 rolls up, two ½ rolls down
    From upright, pull through a 3/8 loop into a 45° upline, perform four 1/8 rolls, pull through a ¾ loop into a 45° downline, perform two ½ rolls, push through a 3/8 loop, exit inverted.
    F-15.10 ½ Square Loop on Corner with ½ loop integrated in ¼ loop
    From inverted, push through a 1/8 loop into a 45° upline, push through a ¼ loop nto a 45° upline, while performing a ½ roll integrated in the ¼ loop, pull through a 1/8 loop, exit inverted.
    F-15.11 Horizontal Hour-Glass with two ¼ rolls, two ¼ rolls in opposite direction, two ¾ rolls in opposite directions
    From inverted, pull through a ¼ loop into a vertical downline, pull through a 3/8 loop into a 45° upline, perform two ¼ rolls immediately followed by another two ¼ rolls in opposite direction, push through 3/8 loop into a vertical downline, push through a 3/8 loop into a 45° upline, perform a ¾ roll immediately followed by another ¾ roll in opposite direction, pull through a 1/8 loop, exit inverted.
    F-15.12 Reverse Immelman with snap roll
    From inverted, perform a snap roll and immediately pull through a ½ loop, exit upright
    F-15.13 Figure 9 with four ¼ rolls up, ¾ loop with roll integrated in top 180°
    From upright, pull through a ¼ loop into a vertical upline, perform four ¼ rolls, pull through a ¾ loop while performing a roll integrated in the top 180° of the ¾ loop, exit upright.
    F-15.14 ½ 6-Sided Loop with with ½ roll
    From upright, push through a 1/12 loop into a 30° downline, push through a 1/6 loop into a vertical downline, perform a ½ roll, pull through a 1/6 loop into a 30° downline, pull through a 1/12 loop, exit upright.
    F-15.15 Roll Combination with four rolls in opposite directions
    From upright, perform four rolls in opposite directions, exit upright.
    F-15.16 Pull-Pull-Pull Hupty-Bump with roll up, roll down
    From upright, pull through a ¼ loop into a vertical upline, perform a roll, pull through a ½ loop into a vertical downline, perform a roll, pull through a ¼ loop, exit inverted.
    F-15.17 45° Stall Turn with six 1/8 rolls up, 1 ¼ snap roll down
    From inverted, push through a ¼ loop into a vertical upline, perform six 1/8 rolls, perform a stall turn into a vertical downline, perform 1 ¼ snap roll, exit upright.
    Laatst bewerkt door een moderator: 12 apr 2010
  2. Alexzzz
    Alexzzz Moderator Moderator team Forum veteraan
    5 mei 2004
    Spijkenisse
    Waar heb je dit vandaan?
  3. Henri Zikken
    Henri Zikken Guest
  4. bob_romijn
    bob_romijn
    23 aug 2005
    Haalderen
    Dit zijn inderdaad de voorstellen zoals ze uitgewerkt zijn.
    Ze moeten nog wel door de vergadering (Lausanne dacht ik) goedgekeurd worden.
    Enig commentaar uit de jurtwereld (internationaal):
    P15.14: Ondoenlijk om dit figuur normaal vanuit middenlijn te vliegen. Iets anders moet het worden.
  5. Henri Zikken
    Henri Zikken Guest
    Dat is inderdaad een leuke.. bij de variant omhoog zie je mensen (ik iig) al vaak te hoog uitkomen, alleen omlaag is dat problematisch :p
  6. nando
    nando Forum veteraan
    18 jun 2004
    apeldoorn
    Ik kom niet helemaal uit die site, kun je een linkje posten naar de aresti's bij het programma?
    Dat is om een met een korte blik een indruk te krijgen iets overzichtelijker.
    Ik heb met google de aresti van F13 gevonden, [F3A-Discussion] Schedule Proposals F-13/15
    Laatst bewerkt: 13 apr 2010
  7. Henri Zikken
    Henri Zikken Guest
    F13 stond ook al in mijn post ;)
    als je op die link van mij onderaan steeds 'previous post' doet, kom je uiteindelijk bij de oorspronkelijke post en attachments uit. Of daar aresti bij zit weet ik niet, er zaten .bin bestanden bij, dus mss wel?
  8. nando
    18 jun 2004
    apeldoorn
    Oke, post aangepast... :rolleyes:
    Met previous kom ik niet zo ver, maar ik ga nog wel verder zoeken.
  9. Henri Zikken
    Henri Zikken Guest
  10. nando
    18 jun 2004
    apeldoorn
    :D
    Thanx!
  11. bob_romijn
    bob_romijn
    23 aug 2005
    Haalderen
    Wat opmerkingen hierbij:
    - Volgens de laatste info vandaag wordt waarschijnlijk P15.14 vervangen door een stall-turn met 2/4 punt rol down.
    - Interessante figuren:
    - P13.11: De rollen geintegreerd in de loops van een cubaan
    - P15.3: Meskant in de lijnen van een dubbele immelmann
    - P15.7: 1/6 rollen voor het eerst geintroduceerd zover ik weet
    - P15.10: Hebben we eindelijk door hoe een stallturn gevlogen moet worden, vragen ze nu een wingover.... :)
    De rest is redelijk straight forward. Ik ben er nu redelijk doorheen gegaan en heb m'n commentaar gegeven richting organisatie en ik denk dat het leuke programma's zijn die door de beginnende F3A-er gevlogen kunnen worden maar de crack heeft er ook genoeg uitdaging in (Als je nagaat dat P-09 eigenlijk wat te simpel was)
    BTW: Alle programma's zijn nog zeker niet officieel!
  12. nando
    18 jun 2004
    apeldoorn
    Ik heb vandaag op de sim P13 2 keer gedaan, die viel mij idd op, erg lastig maar leuk figuur.
  13. 1crash2often
    1crash2often
    20 nov 2005
    Epe
    Zijn de definitieve programma's nu bekend?
    Volkert
  14. 1crash2often
    1crash2often
    20 nov 2005
    Epe
    heeft iemand hem al gevlogen? Leuk programma maar wel lang! Als ik het volledig vlieg red ik het net op een 4900mAh accu (of net niet...).
    Volkert
  15. Ed Heemskerk
    Ed Heemskerk
    5 sep 2007
    Lisse
    Ik heb het P13 programma nu 20X gevlogen.
    De figuur 2 is een nieuwe, de stallturn in de vliegrichting is in het begin erg lastig.
    Het model stallt alleen wanneer in het 2 e gedeelte na de 1/4 e rol het model tegen de wind in wordt geduwd met richting.Doe je dit niet dan lukt het niet.
    Met wind mee stallen gaat ook niet want dan wordt alleen een wing over gemaakt.
    Ook de figuur 15,de tegengestelde rollenpartij is een hele uitdaging.
    De meskantdiamant lijkt heel moeilijk maar wordt niet zo ervaren.
    De Oxalys gebruikt met het P13 programma met windkracht 5 3200-3300 Ma.
    Met het 4400 Ma pakket kan ik zelfs nog een paar figuren extra maken.
    Probeer eens een kleinere propeller als het gebruik aan de grens van de capaciteit komt.
  16. ralph123
    ralph123
    31 mei 2007
    Holland
    Ed, heb jij de Ned vertaling van het P-13 programma? zo ja, zou je hem dan door kunnen mailen/posten?
    groet.
  17. Ed Heemskerk
    Ed Heemskerk
    5 sep 2007
    Lisse
    De Nederlandse versies van de programma s worden door de subcommissie gemaakt, evenals een figuurbeschrijving en een juryhandleiding.
    Dit is nog niet klaar. Zodra deze klus af is worden de programma s in het reglementenboek van de KnvvL geplaatst.
    Door de programma s te vliegen kom je mogelijke fouten of niet aansluitende figuren tegen.
    Ik heb zelf een coach versie gemaakt voor het A 12 en het P13 programma.
    Er komt ook een coachformulier beschikbaar op de F3A site.
    Stuur in een PB even je E-mail adres,mag je die wel zolang gebruiken
