Te koop : BaseCam (AlexMos) SimpleBGC
Discussie in 'FPV (First person view)' gestart door jorrie, 28 okt 2015.
  1. jorrie
    jorrie
    2 jul 2009
    This is the original BaseCam SimpleBGC 8-bit controller board (formerly also called AlexMos). While this board has been superseded by the 32-bit version, this 8-bit version is still available in the marketplace and is actively used and supported. It still produces outstanding results. Without the extension board this controller can be used for building high-quality 2-axis camera stabilizing systems. The controller can also be used for 3-axis control systems with the addition of the extension board. In either case, from a functional perspective the newer 32-bit board is 100% backward compatible with this board, and users of this board can freely upgrade systems from this board to the newer 32-bit board. In addition the management software is backward compatible, so it is possible (or preferred) to use a new version of the GUI (SimpleBGC�s management software) with this board- giving an improved experience with this board and also further making upgrade to the 32-bit board as easy as possible.
    http://www.basecamelectronics.com/simplebgc/
    Originele prijzen staan erbij,
    Doe een leuk bod voor overname
    Alex Mos Brushless Gimbal Elektronics incl. Sensor
    1 92,44 EUR 92,44 EUR
    3rd Axis Ext. Board for AlexMos Board
    1 37,82 EUR 37,82 EUR
    Flyduino G2208 0.18mm 80 Turns Motor for Alex Mos Gimbal
    3 27,65 EUR 82,94 EUR
    SH1.0 4 poliger I2C Stecker 25cm
    2 2,86 EUR 5,71 EUR
  2. jorrie
    jorrie
    2 jul 2009
    Schopje.
    Mag weg voor een leuk bedrag.
