1:6 mono waterski
Discussie in 'Speedboten' gestart door Lex Verkuijl, 6 mrt 2017.
  1. Unusual RC
    Unusual RC
    19 mei 2004
    Rijswijk, Zuid Holland
    Indeed, amazing achievement!
  2. Lex Verkuijl
    Lex Verkuijl
    30 okt 2004
    Lelystad
    Looking verry good, she runs stable as a rock!
  3. Returntohome
    Returntohome
    3 apr 2022
    Leeds UK
    20220416_055326.jpg Hi thanks ..This blade is only 20 x 4 tapering down to 20 x 2.5 mm but seems very strong , it is flexible but doesn't feel like it would break, flexing might even be an advantage. My problem is it was so complicated to draw I can't get the other side a perfect match.
    I don't see why I couldn't draw both at the same time, repeating each operation as I go. To get the twist I used "blend" , but for some strange reason when doing the right side it refused to blend. Will keep trying feel like I am close now.
    The reason it looks wider at the end is the printing support is still in place.
    Bijgevoegde bestanden:
    Unusual RC vindt dit leuk.
  4. Unusual RC
    Unusual RC
    19 mei 2004
    With the info on RCG I now understand what you mean.
    This sometimes happens in 3D software, that the surfaces cannot be generated for a reason.
    Maybe you know someone with more experience with this software you are using, or a helpdesk or forum?
    I know these issues well in SolidWorks, but every CAD program has it's own annoyances ;)
    Laatst bewerkt: 16 apr 2022
  5. Returntohome
    Returntohome
    3 apr 2022
    Leeds UK
    20220416_095755.jpg It worked , doing them together, so they are identical. I also found a less complicated way which helped no end.
    Printing now for tomorrow, now I have the design I can tweek it no end of ways, wider, longer, anything
    I just tried to break the one I printed, it wouldn't, using a lot of force it bent, then I bent it back. Stronger than ally
    Carbohans en Unusual RC vinden dit leuk.
  6. Returntohome
    Returntohome
    3 apr 2022
    Leeds UK
    20220416_162517.jpg 20220416_162526.jpg 20220416_162509.jpg 20220416_162553.jpg These look neat, will they work? we shall see tomorrow.
    Dim L, Gerrit-Jan en Unusual RC vinden dit leuk.
  7. Returntohome
    Returntohome
    3 apr 2022
    Leeds UK
    They are so light it altered the c of g 16 g lighter than last working set ,. So tends to fall over. Solutions. 1st. I have removed 10 g from her legs and I am going to add a fin at the back of the ski that should add weight where it's needed.
  8. Lex Verkuijl
    Lex Verkuijl
    30 okt 2004
    Lelystad
    You dont need weight, jou need to give the center horizontal part off the foil some negatieve pitch. The whole trick with this ski is the ski and the foiltips generating lift, while the center part of the foil pulls everything down. From that you get the balance.
  9. Returntohome
    Returntohome
    3 apr 2022
    Leeds UK
    Yes I have understood that all along, clever idea. So these are at the same angle as last time , but the difference is not only the weight, but the shape in cross section. These are oval shape 20x4 and tapering down to 20x2.5 at the tips, last time was about 35x6 and rectangular cross section with a sharp front edge, which would definitely create more down force. I have to consider printing which means having the back edge all equal except for the tips which can have supports for breaking off later. So I could have the horizontal section say 30mm wide , flat bottom, sharp front edge, rising up to 6mm thick. The rest could stay as 20x4 oval .
  10. Returntohome
    Returntohome
    3 apr 2022
    Leeds UK
  11. Lex Verkuijl
    Lex Verkuijl
    30 okt 2004
    Lelystad
    For down force you would have to flip the centre part, so the flat surface is topside. That way the foil profile works in the correct direction for pulling down. With the flat side down you get a lifting configuration.
  12. Returntohome
    Returntohome
    3 apr 2022
    Leeds UK
    I see , easy to do that, like an upside down aeroplane wing. 16502728231712065162339.jpg Just for fun I have added a fin to the blade support, do you think it will have any effect? What angle were you working to to get the horizontal at the right position. I find it amazing you did this straight off without loads of testing
  13. Lex Verkuijl
    Lex Verkuijl
    30 okt 2004
    Lelystad
    I fin will have little or no effect I think, except increasing drag.. You already have vour fins: the vertical foil parts that go up and down! You could use the fin to mount the foil to though, to eliminate the doubble support downward.
    I hate to burst your bubble, but my skier didn't run well at all in the first! Far from that! I started with a much smaller version (maybe 1/10 or 1/12 scale) some years ago, and then went for the 1/6 scale version. I have used 2 or 3 aluminium foil shapes before I got the right one. Still bending it slightly every now and then, to tweek the way it runs. So for me it is verry interesting to see your work now. If you get a relyable 3D printable shape that could be used as a universal foil, it would greatly ease things for anyone who wants t build one. It would eliminate a lot of testing, and trail en error runs!
    Laatst bewerkt: 18 apr 2022
  14. Returntohome
    Returntohome
    3 apr 2022
    Leeds UK
    20220418_110748.jpg 20220418_110641.jpg 20220418_110404.jpg I am printing a foil now with the inverted wing on the horizontal. Nice of you to help me Lex
    Dim L en Unusual RC vinden dit leuk.
  15. Returntohome
    Returntohome
    3 apr 2022
    Leeds UK
    20220419_064552.jpg Fresh of the printer , looks cute with it's little wing. I think my figure weighs 137grams, how does that compare to other figures I've seen on this thread?
  16. Lex Verkuijl
    Lex Verkuijl
    30 okt 2004
    Lelystad
    Not sure. Mine is glued to the ski, cant weight her seperately. Should be about the same through.
  17. Returntohome
    Returntohome
    3 apr 2022
    Leeds UK
    The foils grew wings but they won't be flying
    Tamiya1970 en Dim L vinden dit leuk.
  18. Returntohome
    Returntohome
    3 apr 2022
    Leeds UK
    Not much luck today, this is not easy, I need to redraw the curved foil to give more lift at the sides, as I can't bend it I will just have to hope i hit on a good shape.
    I will use my ally foils as a guide, they can work well. Another idea is printed round both bends then slot in the ally, glued in, might do both.
    Laatst bewerkt: 20 apr 2022
    Dim L vindt dit leuk.
  19. Lex Verkuijl
    Lex Verkuijl
    30 okt 2004
    Lelystad
    Heat the foils up with a smal torch or hot air blower, and when it gets soft bend it in the desired shape. After cooling its solid again. Should work at the lake side, at least for testing and getting the shape right before designing the final version.
  20. Returntohome
    Returntohome
    3 apr 2022
    Leeds UK
    Great idea, we have a workshop in the clubhouse, I have a hot air gun I can take with me. Hope I might get lucky and won't need it.
