Mick Reeves Sopwith Camel
Discussie in 'Vliegende schaalmodellen' gestart door strutter, 19 jan 2007.
  1. strutter
    strutter PH-SAM
    17 sep 2006
    Haarlem
    Hallo Jeroen,
    De Camel is vliegklaar
    Vertraging zul je zelf moeten uitwerken
    Hier wat info van Mick Reeves:
    TORQUEMASTER for Zenoah Titan 62
    This unit bolts onto a Zenoah 62 engine and provides a belt driven reduction drive to a new prop shaft set in front of the cylinder. This enables a larger propeller to be driven, which is more efficient and gives greater thrust.
    Why is a Reduction Drive needed and what advantage does it give? This is a difficult question to answer fully but a simple analogy will help. It's rather like the gear box on a car. Try pulling away in top gear and you will find that it is a great struggle and acceleration will be very slow until you reach a reasonable speed when the clutch can be fully engaged and the car will then accelerate to high speed. This situation can be compared to an engine fitted with a small diameter prop, or ducted fan or turbine. Acceleration from rest can be poor but performance is good once a high speed is reached.
    The propeller or fan in this case is very inefficient at low speeds. Most of the energy is wasted in turbulence behind the model. Modern ducted fan models overcome the slow acceleration problem by using a very powerful engine, perhaps four times the power used in a similar sized propeller model.
    The opposite case, pulling away with the car in bottom gear gives very good acceleration from rest but, of course, the car will not go very fast. If you are pulling a very heavy trailer uphill then bottom gear might be just right for the situation. The equivalent case for a model aircraft (or full size aircraft come to that) is a large, heavy, slow flying machine, where a high ratio reduction drive could turn a large prop to give the thrust needed to fly the model. But you don't get this extra thrust for nothing - the theoretical top speed available will be proportionately lower, although the model can actually reach a higher speed in practice because of the improved efficiency.
    Most large scale models would lie somewhere between these two cases and most of these would benefit from using a reduction gear.
    Propeller efficiency. This concept is rather difficult to explain. The propeller thrust must equal the drag of the model at a particular speed and the thrust is obtained by the propeller throwing back a column of air faster than the model is flying. The thrust is calculated from the mass of air x change in velocity.(MV) Therefore, a large prop, moving a large column (and mass) of air, can throw the air back at a low speed to achieve this thrust, whilst a small prop would need to provide a much higher speed column of air to get the same thrust. The difference between the rearward speed of the air from the prop and the forward speed of the aircraft is referred to as propeller slip and the greater the slip, the less efficiency.
    Mathematical explanation:- Thrust is given by M x V , BUT the energy lost in the slipstream is given by 1/2MV2. Work it out and you find that the smaller prop with higher velocity change has much higher losses for the same thrust.
    Deciding on whether a particular model would benefit , and deciding what prop size would be appropriate, is quite a problem. It is possible to calculate this provided all the facts are known but normally we do not have enough information available to make calculations worthwhile. You would need to know the speed and drag of the model; the torque curve of the engine; the thrust and torque absorption curves of various props etc. A more practical way to decide is to look at existing models which are successful with the standard engine and then look at slightly larger heavier models which can fly on the straight engine but where the performance is marginal during takeoff and climbing. This is where the torquemaster can be a real benefit. My 1/3 scale Camel is 112" span and weighs 3Olbs. The King 100 engine used in this model turned a 28 x 14" prop. at 42-4400 rpm. This gave good performance but fitting the Zenoah 62 and Torquemaster resulted in an extra 200 rpm on this prop and vertical performance with the much smaller engine.
    A rule of thumb for deciding what propeller pitch to use is to aim for a 30% propeller slip. So if the model is flying at 40 mph it will require prop pitch equivalent to 57 mph ( 40 /0.7) At 5000 rpm this needs 12 inch pitch. ( MPH X 1056) RPM One would then adjust the prop diameter to reach the required rpm. The Manufacturers' power graphs for the Zenoah 62 suggest that maximum power is 4 BHP at 8500 rpm (silenced), and my engine appears to run quite happily at 9500 rpm. If you want maximum performance then you should select a prop which will allow the engine to reach these speeds, but a bigger prop might be preferred to reduce noise, engine wear and fuel consumption. My approach with the Camel was to prop for around 8000 engine rpm at full throttle, giving near maximum power but only using full throttle very rarely in flight. Level flight requires only 1/4 throttle and scale aerobatics can be done on about 1/2 throttle. It's nice to have the extra performance in hand for use when you want it.
    I believe that use of the Torquemaster will give great improvements in models over 251bs and will give the impression that a larger engine is being used. Takeoff runs will be much shorter, climb outs can be steeper with good control authority, where using the standard engine would have meant a struggle to get airborne and a slow climbout near the stall.
    Succes, Ralf ;)
    Verder weet ik dat een ZG45 met een vertraging van 2,5:1 een prop van 32x18" rondslingert met ca.3000 rpm
    Dit komt redelijk overeen met je 50cc denk ik
  2. j.weel
    j.weel
    2 feb 2009
    Niet helemaal de 45 drijft max een 20 10 aan
    terwijl de 50 er een 22 10 aankan
    maar een 45 heb ik ook nog liggen
    aleen wat is de maar voor de sopwith pup op schaal
    ik herb nu wat om mee te rekenen dus die vertraging zit wel gtoed kan nu ale kanten op
    wat is bijvoorbeeld de vertraging van de zg 62 en is 3000 r p m niet een beetje wijnig
    ik dacht dat je tog van 4000 uit moest gaan maarja op dit gebied weet ik nog niks
    is de 3000 r p m bijvoorbeeld ook genoeg voor een w w 2 kist
    zoals een spit
  3. strutter
    strutter PH-SAM
    17 sep 2006
    Haarlem
    Ok Jeroen, heb de bekende vertragingen voor je op een rijtje gezet
    Voldoen allen prima voor de Pup ;)
    Toni Clark ZG38 2,8:1 32x18" @2700rpm 2700gram
    Schlundt ZG45 2,5:1 32x18" @3000rpm 3845gram
    Reeves ZG62 1,75:1 30x12" @4000rpm 3600gram
    30x14" @3800rpm
    Schlundt ZG62 2,5:1 34x20" @3000rpm 4150gram
    De laatste wordt op onze 1/3 DVII's gemonteerd
    De Toni Clark drive is het mooiste weg te werken achter een dummy motor
    Bij de Reeves Torquemaster dient er een gat uit de dummy gehaald te worden
    En tenslotte bij de Schlundt drive, welke kwalitatief de beste is, dient er een groot deel van de dummy verwijdert te worden vanwege het ver naar voren liggende vliegwiel
    (is er momenteel eentje te koop 350euro)
    De Reeves Torquemaster was aanvankelijk voor de Spitfire bedacht
    Relatief kleine vertraging
    Bij deze zou mijns inziens optimaal voor een 1/3 WW1 kist een vertraging met 2:1, 2,1:1 zijn met een 32x18"prop
    Groeten, Ralf
  4. j.weel
    j.weel
    2 feb 2009
    Ralf bedankt man
    ik kan hiermee aan de slag
    ik ga de vertragingsjunit zelf maken
    waardoor ik hem zo kan maken als ik wil
    Zou 45 cc genoeg zijn voor de 1/3 pup ik heb nog een oude solo motor liggen
  5. strutter
    strutter PH-SAM
    17 sep 2006
    Haarlem
    Jeroen, 45cc is een goede keuze
    (zou zelf voor de ZG45 gaan..)
    als je de vertraging 2,5:1 aanhoudt kun je mooi de 32x18" draaien
    Perfecte combinatie
    Groet, Ralf
  6. j.weel
    j.weel
    2 feb 2009
    Ralf nogmaals bedankt
    De solo heb ik liggen en die heeft hetzelfde vermogen als de zg 45
    het was de oude motor van de D21 waar nu de 50 pt motor op komt
    ik heb trouwens problemen met mijn 62 zenoah hij start erg slecht
    branstof aanzuigen totdat i zat heeft
    choken
    aanslaan
    hij geeft dan wel een plof maar draait niet door
    aangezien het de motor is die op mijn hurygane zoek ik tog echt naar de oplosing van dat probleem
    we hebben hem met de schow vorige zomen met een startmotor gestart
    toen liep i prima
    maar na 15 minuten vliegen zakte het vermogen ineens weg na een overshoot
    zou i te warm zijn geworden ???
    en zou dat startprobleem verholpen zijn met een electroniche ontsteking
    ik vind het vonkje namelijk erg flouw
  7. strutter
    strutter PH-SAM
    17 sep 2006
    Haarlem
    :oops:
    Afgelopen zaterdag prachtig vliegweer dus de Camel maar eens de lucht ingeschoten
    Na de landing mishap in Oss vorig jaar had ik er niet meer mee gevlogen
    Kabeltjes weer helemaal uitgericht dus; vliegen met die hap! :D
    Vertraagde ZG62 startte snel en liep mooi (blijft een lekker geluidje!)
    Start, mooi los, en toen schrikken!!
    Toestel helt gevaarlijk naar rechts en blijft zo hangen
    Hoogte maken, trimmen, helpt niets, kist blijft naar rechts hangen en is slecht bestuurbaar.
    Bocht naar rechts gaat met hangen en wurgen, linksom gaat goed
    Na 2 rondjes gelukkig weer veilig terug aan de grond weten te zetten
    Weer een paar grijze haren erbij (had er nog niet genoeg :rolling: )en een paar jaartjes ouder
    Wat bleek nu achteraf?
    :oops:
    Iets te onsecuur geweest met de instelhoekmeter
    Foutje bedankt :rolleyes:
    In de Mid sectie zat een instelhoek afwijking van 1,5 graden (!) (tussen de linker,- en de rechterwortelrib)
    Ik dacht dit wel 'recht te trekken' door de vleugels wel de goede instelhoek te geven tijdens het uitrichten..
    Weer een wijze les geleerd:
    Zorg dat het bij dit soort kisten exact netjes opgebouwd en ingesteld is, anders heb je echt een probleem!
    Gelukkig leeft de kist nog en was er geen schade
    Nu mijn huiswerk maar eens goed doen en de boel goed netjes uitrichten
    Jammer hoor, was zo'n mooie dag om eens lekker te vliegen
    Groeten van een ietwat geschrokken Ralf
  8. Berto
    10 okt 2002
    Zeewolde
    Hee Ralf,
    dat zou zeker schrikken zijn, maar gelukkig heb je hem nog heel aan de grond weten te krijgen en die grijze haren daar hebben ze tegenwoordig hele mooie kleurspoelingen voor ;-)
    Gelukkig is de oorzaak bekend en kan vlucht 3 helemaal foutloos gevlogen worden, we kijken er weer naar uit om deze kist op Oss te zien :yes:
    Succes.
    Berto.
  9. Teus
    Teus Guest
    Phoeeeeeee Ralf,
    Wat zal jij met het zweet tussen je bilnaad hebben gestaan. Gelukkig alles goed afgelopen zeg.
    Jammer idd. van zo'n mooie dag, maar je kist is gelukkig nog heel en dat is het belangrijkste. Nu weer mooi uitrichten en lekker gaan vliegen.
    :zon:
    Gr. Teus
  10. j.weel
    j.weel
    2 feb 2009
    pfffffffff gelukkig is het goed afgelopen man had doodzonde geweest als jou juweeltje stuk gegaan was
  11. Bert van Eijk
    Bert van Eijk
    15 sep 2004
    Kimswerd
    Hoi Ralf,
    Gelukkig goed afgelopen. Voor 't zelfde geld ligt de zaak aan spanen, een risico dat wij allen lopen.
    Ik ga nu met de Fly Baby beginnen aan de definitieve bespanning, d.w.z. de instelhoeken en de v-stelling met de kabels erin stellen en dan ....
    wordt het zwaartepunt/balanspunt erin gezet. Uiteraard heb ik van de Fly Baby geen gegevens en ben op zoek. Het is een tweedekker met een beetje peilstelling in de vleugel. Alle toestanden wil ik natuurlijk zoveel mogelijk uitsluiten.
    Heb jij hiervoor gegevens of op andere wijze een tip? Het is natuurlijk al spannend genoeg om een kist met zoveel arbeidsuren de lucht in te laten gaan. Maar eens komt het ervan.
    Ik ben benieuwd.
    Groeten,
    Bert
  12. Teus
    Teus Guest
    @ Bert,
    Misschien kan de exel rekensheet gebruiken op DEZE pagina?
    Even een stukje naar beneden scrollen en daar vindt je Airplane Design Calculator.
    Gr. Teus
  13. jacques.1
    jacques.1
    19 nov 2006
    echt
    hoi bert ,
    dit moet je aan frank hartog vragen (hoop dat ie niet boos wordt dat ik dit doorgeef) hij heeft het zwaartepunt voor mijn dh9 ook uitgerekend en dit zat perfect op de goede plaats :D
    gr jacques
  14. jan brilman
    jan brilman Forum veteraan
    27 sep 2002
    groningen
    Durf me haast niet te mengen onder de experts, maar toch: bouw een 'bok', waarbij de vleugels met de juiste instelhoeken op dragers liggen en gefixeerd worden.
    Oid.
    Dat voorkomt dat je, door de bekabeling aan te brengen en op spanning te brengen, de zaak scheef trekt.
    Heb ik bij mijn Pupje ook tweemaal (tweede keer na een crash) toegepast, en die vloog tweemaal als langs een liniaal . . .
    Just my two cents . . .
    Of gaat het alleen om het berekenen van het zwaartepunt? :oops:
    jan.
    Laatst bewerkt: 15 apr 2009
  15. strutter
    strutter PH-SAM
    17 sep 2006
    Haarlem
    Bert, voor het zwaartepunt kun je je inderdaad beter bij Frank voegen :p
    Mocht je specifieke vragen hebben over het optuigen/afstellen wil ik je graag mijn ervaringen meedelen
    Is een lang verhaal om dat in het geheel zo even uit te leggen ;)
    @jan, steun is zeker een goede optie voor een kleiner toestel
    1/3 kisten zijn ietwat groot voor een steun, je mag al blij zij als je hem ergens kwijt kan in je hok
    Ben nu gereed met afstellen van de kabels, rest nog het zekeren van de turnbuckles
    Het opspannen doe ik op een tafel, hier wat foto's
    Ik heb een redelijk grote zolder tot mijn beschikking maar nu staat hij wel vol
    Groeten en dank voor de positieve reakties heren :D
    Laatst bewerkt door een moderator: 7 dec 2015
  16. jan brilman
    27 sep 2002
    groningen
    Ik zou zeggen: zet hem (en de bokken voor de vleugels) op een vlakke vloer. :p
    Jouw vloer ziet er goed uit. :yes:
    jan.
  17. j.weel
    j.weel
    2 feb 2009
    het zwaartepunt is tog niet zo een probleem
    bij een normale kist licht dat op een derde van de vleugol
    bij pijlvleugols moet je kijken op welk punt je het middepunt van het vleugolopervalkte hebd op dat punt weer een derde
    bij een duboldekker waar de vleugtold staan zoals bij de pup
    is het een derde van de bovenvleugol plus de helft van de avstand die de ondervleugol meer naar achter staat
    bij een kleinere ondervleugol licht het weer anders dan moet er berekent worden wat het opervlakteverschil is tussen de boven en ondervleugol
    dan krijg je een deelsom
    die aangeeft hoeveel van de afstand dat de ondervleugol meer naar achter staat je erbij op moet tellen
  18. Frank Hartog
    Frank Hartog
    25 sep 2006
    Westervoort
    Hmmm,
    oei, oei,
    zal ik het dan maar zeggen: dat gaat niet werken zo :nooo:
    uitgangs waarden voor een normaal vliegtuig zijn grofweg 25% tot 28% van de gemiddelde koorde.
    Met éénderde, dus 33.3% ben je gegarandeerd te staartlastig :yes: (don't ask me how I know:D)
    gr.
    Frank
  19. Bert van Eijk
    Bert van Eijk
    15 sep 2004
    Kimswerd
    He Teus,
    Natuurlijk heb ik zelf ook wel wat, maar kijk en vergelijk is het devies.
    Ik ga de betreffende programma's bekijken.
    Bedankt,
    Bert
  20. Bert van Eijk
    Bert van Eijk
    15 sep 2004
    Kimswerd
    Hoi Jan,
    Gelukkig gaat het enkel om een bevestiging te krijgen op mijn (tot nu toe bepaalde) zwaartepunt. Alle tips en verwijzingen zijn daarbij welkom. :grin:
    De vleugels zijn al zodanig gepast en gemeten dan de instelhoeken en V-stelling met behulp van een bok zijn te plaatsen. Definitief wil in dit verband zeggen dat de bespanning wordt aangetrokken en geborgd en als je daarbij niet oppast trek je de zaak scheef, met moeilijk tot zeer moeilijk vliegen als gevolg.
    Bedankt voor het meedenken,:worship:
    Bert
    Ik ga nu weer voor vragen en verslagen naar mijn "eigen" draadje.
