Waterland rc scale boats ,classic cat
Discussie in 'Speedboten' gestart door Tamiya1970, 26 mrt 2021.
  1. Tamiya1970
    Tamiya1970
    31 mrt 2012
    De wsb op het Henschotermeer
    Returntohome, Dirk Jan, HeliKoper en 2 anderen vinden dit leuk.
  2. Carbohans
    Carbohans
    17 nov 2019
    Maasdam
    Geniaaaaal
    Tamiya1970 vindt dit leuk.
  3. Dim L
    Dim L
    18 aug 2021
    Athens, Greece
    Fantastic run Alex and very lucky with this flip!
  4. HeliKoper
    HeliKoper
    19 okt 2006
    Guinea-Fowl-City
    De tunnel werkt dus wel errug goed! :thumbsup:
  5. Tamiya1970
    Tamiya1970
    31 mrt 2012
    Dat is een trein op rails.
  6. Dim L
    Dim L
    18 aug 2021
    Athens, Greece
    I am wondering about your flex shaft Alex. Has the lower kv setup helped?
  7. Tamiya1970
    Tamiya1970
    31 mrt 2012
    No Dim.
    the new flexshafts from stumbfac USA are terrible.
    Very hard so not the same as the K&B ones.
    After three runs it was broken allready.
    Made an brass liner tube now,so hopefully that wil help.
    Below some pictures of the broken shaft,it seems to be getting really hot and then broke.
    Wil make an oiler cup maybe on top of the outboard.
    But don't want to spil oil into the lake also.
    [​IMG][​IMG][​IMG]
    Dim L vindt dit leuk.
  8. Dim L
    Dim L
    18 aug 2021
    Athens, Greece
    Brass tube may help indeed. The oiler is also a good idea that I was also thinking about!
    Any eco friendly oil available out there?
    And an irrelevant question about Tamiya rc: Are they reliable in terms of their plastics? I want a CC-01 Toyota Hilux for a very long time and I always hesitate due to high replacement cost of broken parts!
  9. Tamiya1970
    Tamiya1970
    31 mrt 2012
    Reliable for sure ,and parts are not expensive for a CC 01.
    Only thing is you must get a ballbearing set for the Tamiya , normally not included.
    Included are nylon bearings.
    And they are pretty poor ,and were out instantly.
  10. Dim L
    Dim L
    18 aug 2021
    Athens, Greece
    Thanks Alex! I have seen these ball bearing kits:thumbsup:
