Thanks [emoji106] Yes, close to the 100 km/h. I guess with a higher performance lipo, I could crack it.
But.. as Eric mentioned before, the higher the speeds, the bigger the crashes.
I check the hull carefully after each crash and I notice a very light paint crack at one of the sponson bottoms. I will strip the paint to check the actual damage.
What's worse is that I destroyed 2 steering servos already. The impact after a flip destroys the gears. I'm missing a servo saver here, just like rc cars have.
I might go down a little on the setup. Keeping the boat on the water saves money!
On the other side, the 120A esc and 3674 motor are holding up great, even with the aggressive props and warmer water temps.
This is the same spot as previous videos. Just from another shore angle [emoji3]
