KJ66 Conversies
Discussie in 'Zelfbouw turbines' gestart door Gerald Rutten, 28 aug 2005.
  1. jetflydemoteam
    jetflydemoteam
    20 dec 2011
    Keron232 vindt dit leuk.
  2. jetflydemoteam
    jetflydemoteam
    20 dec 2011
    first test i reach 98k ..trust 11,5kg 487°c
    then compressor fail....
    the photo show different type of aluminium wheel
  3. Gerald Rutten
    Gerald Rutten
    6 mei 2005
    Zuidelijk
    Ooops.....:schrik:
    I assume thats a cast failure?? 98K is very low, did you experience some surge just before? Engine running cool and good before failure. Hope nothing more is damaged.
    Rgds,
    Gerald
  4. jetflydemoteam
    jetflydemoteam
    20 dec 2011
    first accelleration ramp was very slow, no hot spot and other
    no damage ...only big imbalance after failure
    the compressor debris touched the diffuser under compressor...but no damage
    only bearing to change.. (now is noisy)
    i see that last compressor is made in dark aluminium look instead light about previous one
    the egt was stable from idle to 98k from 450° to 550° in acceleration
  5. jetflydemoteam
    jetflydemoteam
    20 dec 2011
    today another test ext. temp. 2°c
  6. jetflydemoteam
    jetflydemoteam
    20 dec 2011
  7. G J Broekhuizen
    G J Broekhuizen
    12 jul 2004
    Elburg
    kj 66
    very beautiful.
    but i hear your bearings a little bit.
    That,s nog good for the lifetime of your bearings
  8. jetflydemoteam
    jetflydemoteam
    20 dec 2011
    many thx;);)
    there was noisy bearing used in other test engine... need to change with news when engine will be ok... no imbalance when running
  9. jetflydemoteam
    jetflydemoteam
    20 dec 2011
    working on another two diffusors
  10. G J Broekhuizen
    G J Broekhuizen
    12 jul 2004
    Elburg
    frees machine
    Mooi Hobby bankje
    Nice hobby tool
    Laatst bewerkt: 19 dec 2013
  11. jetflydemoteam
    jetflydemoteam
    20 dec 2011
    one of 5x machine of factory
    the diffuser is made simply in 3x mode
  12. htto
    htto
    18 okt 2012
    jetflydemoteam one of 5x machine of factory
    Why, If you can use 5x?
  13. jetflydemoteam
    jetflydemoteam
    20 dec 2011
    because other machines are busy ;)
    this geometry is simply to made ...3x is ok...to work (only 2 tools used)
    if the diffusor should be 2 stage design 5x machine is very useful
  14. ahmed atta
    ahmed atta Guest
    Dear Gerald,
    i'm in my way to manufacture my jet and i need your help to buy bearing and turbine 85 mm
  15. Gerald Rutten
    Gerald Rutten
    6 mei 2005
    Zuidelijk
  16. jetflydemoteam
    jetflydemoteam
    20 dec 2011
  17. nzjet
    nzjet
    15 jan 2014
    I am also building some UT-160's I thought it was easier to make 10 at the same time... Are there any mods I should know before I build the chambers?
  18. jetflydemoteam
    jetflydemoteam
    20 dec 2011
    hello...nice work... in my opinion ut160 must to be modified in the diffusor and CC
    like FREMA indications
  19. ahmed atta
    ahmed atta Guest
    hello,
    How could i choose the best impeller Diameter corresponded with tubine diameter ??
    and what is the parameters changes with the diameter of both ?
    thanks
  20. Gerald Rutten
    Gerald Rutten
    6 mei 2005
    Zuidelijk
    Hi Ahmed, I don't do any calculations, mostly trial and error....;)
    That said, diameters of both wheels should be same in most cases and works fine. However, when having a good engine with efficient NGV/turbine combination we can increase impeller diameter to max 106% compared to turbine diameter. This wil give some increase in power for the same engine diameter/weight. (With different reaction turbine we can go even further but that only gives more torque to the shaft, no more direct power, good for turboprop engines)
    Here some comparison for a typical 80N engine with 66mm turbine wheel:
    66mm = 84N thrust @ 120K rpm
    68mm = 96N
    70mm = 108N
    70mm turbine wheel:
    70mm compressor 140N thrust @ 120K rpm
    72mm = 160N
    74mm = 180N
    Data above gained via tests, not calculated.
    Hope this helps?
    Best regards,
    Gerald
