Dank Wim, gelukkig simpel te doen, alleen wel vreemd dat deze binnen een jaar leeg is.Even zoekopdracht : RTC batterij wisselen frsky x 20 , en joep buis met filmpje.
Soms helpt het om even de accu er uit en er opnieuw in te doenBeste ik heb het gedaan maar het schrem blijft black mvg benny
-- 0.1 First attempt
local version = "0.1"
local translations = {en="Colored Timer"}
local function name(widget)
local locale = system.getLocale()
return translations[locale] or translations["en"]
end
local function create()
return {color1=lcd.RGB(0xEA, 0x5E, 0x00), color2=lcd.RGB(0x00, 0x00, 0x00), source=nil, value=0, fontsize=FONT_STD}
end
local function paint(widget)
if widget.source == nil then
return
end
lcd.font(widget.fontsize)
local w, h = lcd.getWindowSize()
-- local text_w, text_h = lcd.getTextSize("")
if widget.value < 0 then
-- Inactive background
lcd.color(widget.color2)
lcd.drawFilledRectangle(0, 0, w, h)
else
-- Active background
lcd.color(widget.color1)
print("lcd.color"..widget.color1) -- debug
end
-- Timer
timer = model.getTimer("Flight")
lcd.color(BLACK)
lcd.drawNumber(2, 2, timer:Value(), CENTERED)
end
local function wakeup(widget)
if widget.source then
local newValue = widget.source:value()
if widget.value ~= newValue then
widget.value = newValue
lcd.invalidate()
end
end
end
local function configure(widget)
-- Source choice
line = form.addLine("Source")
form.addSourceField(line, nil, function() return widget.source end, function(value) widget.source = value end)
-- Active Color
line = form.addLine("Active Background Color")
form.addColorField(line, nil, function() return widget.color1 end, function(color1) widget.color1 = color1 end)
print("addColorField"..widget.color1) -- debug
-- Inactive Color
line = form.addLine("Inactive Background Color")
form.addColorField(line, nil, function() return widget.color2 end, function(color2) widget.color2 = color2 end)
-- Font (XS, S, STD, L, L Bold, XL, XXL)
line = form.addLine("Font Size")
form.addChoiceField(line, nil, {{"Extra Small", FONT_XS}, {"Small", FONT_S}, {"Standard", FONT_STD}, {"Large", FONT_L}, {"Large Bold", FONT_L_BOLD}, {"Extra Large", FONT_XL}, {"Extra Extra Large", FONT_XXL}}, function() return widget.fontsize end, function(value) widget.fontsize = value end)
end
local function read(widget)
widget.source = storage.read("source")
widget.fontsize = storage.read("fontsize")
widget.color1 = storage.read("color1")
widget.color2 = storage.read("color2")
end
local function write(widget)
storage.write("source", widget.source)
storage.write("fontsize", widget.fontsize)
storage.write("color1", widget.color1)
storage.write("color2", widget.color2)
end
local function init()
system.registerWidget({key="status", name=name, create=create, paint=paint, wakeup=wakeup, configure=configure, read=read, write=write})
end
return {init=init}
Dat had ik al gedaan maar dan werkt het nog niet maar de module krijgt wel stroomHet enige wat ik kan denk is dat je in het menu RF system de externe modulle moet aan zetten.
Kan ik helaas niet vindenEr is ook een LUA script dat je moet installeren las ik op rcgroups, vermoedelijk kun je dat dan vinden bij FrSky op de website...
BedanktOf deze met wat meer uitleg: https://www.rcgroups.com/forums/showpost.php?p=49550649&postcount=18844
Je zal even moeten kijken welke de meest recente of uitgebreidste is.
Je mist de hele reden dat de Multiprotocol module ontwikkeld is, en dat is om met je dure zender ook allerlei andere RC speeltjes en BNF spul te kunnen besturen. Ook voor overstappers die nog goede ontvangers van hun oude merk in gebruik hebben kan het een uitkomst zijn.
Idd dat is precies de bedoelingGewoon FRSKY ontvangers dan heb je dat geneuzel niet meer.
Dure zender laten werken met crap recievers is vragen om problemen.
Nieuwe FRSKY Tandem 6 kanaals kost 39 euri waar praat men dan over
